Coilover Cleaning/Care
Old Mar 14, 2013 | 08:58 PM
kyoo's Avatar
Originally Posted by alleggerita
Yup
Interesting - have you tried it on your car? No ill effects I presume?
Old Mar 15, 2013 | 07:31 AM
formulared's Avatar
Boeshield T9 works well. It does not attract dirt and leaves a waxy film that protects. It was originally developed to protect aircraft magnesium landing gear from de-icing chemicals. It will leave a slightly matte finish and can be cleaned off with WD40 or similar. It's usually available at chandlers and marine suppliers.
+1
Definitely a good investment for your coils.
Old Mar 15, 2013 | 11:43 AM
kyoo's Avatar
^ seems to be the case
Old Mar 15, 2013 | 08:17 PM
WRC-LVR's Avatar
Vinegar is an acid. Dont put it on your really expensive struts. that's for real !!
Better yet, just take them off and give them to me wink just kidding
Congrats kyoo !!
Old Mar 16, 2013 | 03:42 PM
kyoo's Avatar
Congrats kyoo !!
thanks for that tip! I knew sometimes it was used for cleaning salt from carpets, and also used for cleaning humidifiers, but that is good info. Thanks
Old Mar 20, 2013 | 07:54 PM
SmurfZilla's Avatar
Great suspension.
Great minds think alike.
Old Mar 20, 2013 | 09:39 PM
kyoo's Avatar
Originally Posted by SmurfZilla
Great suspension.
Old Mar 21, 2013 | 12:40 PM
kyoo's Avatar
lol has anyone ever thought of using seran wrap as a quick/temp cover for the threads?
Old Mar 21, 2013 | 01:01 PM
artinist's Avatar
it will most likely melt due to the heat coming from the calipers, unless they make one that is meant to be used in the oven. the regular stuff is not.
Old Mar 21, 2013 | 01:09 PM
kyoo's Avatar
ah good point.. withstands microwave but idk how hot that is
Old Mar 21, 2013 | 01:48 PM
heel2toe's Avatar
I wouldnt be so sure about that. Another hobby of mine other than cars is cooking bbq'n baking etc. Anyway I love making baby back ribs. If you are a rib person, you know that the meat must fall off the bone. A couple years ago I had the opportunity to meet the owner and chef of a local successful restaurant. I was chatting with him for a while and sure enough I asked him some questions on making ribs. He taught me a trick to help the meat fall off the bones of ribs. His secret was to wrap the ribs in saran wrap and then in aluminum foil and bake them on low heat in the over for about 6 hours. The process creates steam and helps to let the meat fall off the bones. I figured the saran wrap would melt from the heat however to my surprise it did not.
Now I know I am completely off topic here however I wanted to share this story because I thought it was sort of relevant. The oven temp is around 250F btw. I know the brakes will get significantly hotter than that however how much of that heat is transferred to the shocks?
Old Mar 21, 2013 | 01:52 PM
kyoo's Avatar
Interesting... for me it'd be all highway and light on brakes, so may be possible? i'm doing doing a track day lol just need to visit my parents this weekend
Old Mar 21, 2013 | 01:59 PM
heel2toe's Avatar
Well in that case I dont see why not!
Old Mar 21, 2013 | 02:31 PM
WRC-LVR's Avatar
Interesting....I use foil wrap and bake them with dry rub at 300 F for 3 hours well sealed, then open and paste with sauce evry 15 minutes for 1 more hour...they fall off the bone !!
BBQ masters program says they should not fall off the bone but be easily pulled from bone
I really would not use saran wrap as the temp ( 250 F) will tend to release bisphenol A and B from the plastic...check it out
Sorry and back on topic :-)
Old Mar 21, 2013 | 02:40 PM
WRC-LVR's Avatar
Not that much. doubt if they get more than 140 F...Kyoo if you have an IR temp gun then get a reading off the knuckle, the base of the strut and 1/2 way up the strut...
L8r
