Adjustable Rear Lower Control Arms
12k front 10k rear, just the off the shelf setup. front sway bar has just had forward mounting holes drilled to have a stiffer adjustable option. that has been working nicely. i don't have any more wheel lift so i am happy with where my sway bars are sorted.
caster i'm not sure on the current figure, but it's not super aggressive. i have more adjustment on the top hat, but i want to also add the perrin offset bushings. it's better for overall geometry to make the adjustments at the bottom if you can. i know this would help me be able to run less static negative camber in front. i'm constantly working through development on the whole car and kind of taking one thing at a time.
thanks for the info on those arms, i'll look into them. -5 rear would be more than enough for sure. how long have/did you have them and any other issues?
I just bought the AFI adjustable LCAs and DME toe arms from deylag. The reason I went with them is that given my ride height and desired camber, I can't get the toe I want. The alignment tech told me either I would get the camber I want, or I would get the toe I want, but not both (with the stock setup). My rear camber is around -3.0.
Yeah road race setup will be significantly different than autocross. I am running similar times to the 996 porsche cup cars. I run full competition slicks, they require a lot more camber than r compound tires. Michelin recommends -3.5 to -4.5 optimal camber settings, and they have a lot stiffer sidewalls than others, Pirelli for example require more camber as they are super soft. I don't need -5 in the back, i said above i will probable need 1/2 to 1 degree more in the rear based on how they are wearing right now. It's really not out of the ordinary for the whole setup.
Stiffer rear springs is the first I've heard about that, my front to rear weight distribution is quite a bit heavier in front so it seems logical to have stiffer fronts, no? My corner balance (me in the car, 5 gallons fuel) is as follows:
LF: 893 RF: 884
LR: 590 RR: 550
As far as overall feel of the car, it's really neutral and feels great. I am not overdriving the shocks or springs, but I still want to play with different rates also. I'm sure I can improve the setup all around, and that's what I have been doing with the car over the last couple years. I'm not disagreeing with you guys, and am enjoying this discussion, thanks.
LF: 893 RF: 884
LR: 590 RR: 550
AS far as spring rates front to rear are concerned the reason you want stiffer rates in the rear has to do with the suspension geometry. We have a McPhearson strut front and Multi-link rear. If you look at how the control arms are attached you will see that the rear is mounted more inward such that there is more leverage which requires a stiffer rate to compensate.
Now these isnt a one size fits all rate as depending on driver preference as well as weight reduction which you mentioned these all come into play.
Personally as I mentioned prior I would suggest upping the rates in the rear for starters and see how the car responds to that. From there I would tweak the alignment and dial in more camber.
I actually created a simple spring rate calculator on Google Docs a while back to try and figure things out a little better than trial and error. The front/rear motion ratios I used were based on figures I've read either on this forum or somewhere else, I can't remember. Someone like DallasJ probably has done all the legwork to actually figure them out.
https://docs.google.com/spreadsheet/...kE&usp=sharing
if you lower the rear ride height you can get more negative camber out of it. I've measured up to -3.6° but you can only go so low before you max out the articulation of the upper ball joint. stiffer rear springs will help you get low without maxing the ball joint. i probably wouldn't go any stiffer than a 26k rear spring with a 27mm rear bar though.
update on my car, and now more confused. I have 16k rear springs, green tein with stamped part number. i have no idea what my front springs are, they are black and have no markings on them at all. i would think 16k rear is plenty of spring rate, but i'm still getting outer shoulder tire wear, i think it just needs more camber still.
You might want to find out what the rates are for your front springs. And have you messed around with tire pressures? Maybe you do indeed just need more camber but I think you should get your rates figured out first then go from there.
18x10.5 with 280/650-18 (varying), the tires aren't bulging/rolling over, just outer shoulder wears more than inside in the rear. fronts wear really even across the whole tire.
