Ohlins Flag L
Old Jun 20, 2013 | 02:51 AM
dominicsia's Avatar
Ohlins Flag L
Hi, Im new here. I just bought a Ct9a ohlins Flag L coilover and im installing it to my Cp9a. Everything fits fine just that i notice the rear coilover is just too low. I cannot seem to find a solution to higher the heights and it just doesnt seems right. The front is ok but the rear i have already adjust it to the max height and still my tyre is inside the wheel arch.
Old Jun 21, 2013 | 01:58 PM
sujinX's Avatar
Did u adjust by spinning the collar or by spinning the threaded cylinder? Because u can spin the treading out as well just don't go pass the factory marking. Read the instructions.
Old Jun 30, 2013 | 08:43 PM
dominicsia's Avatar
I am spinning the bottom part which is to be mounted to the car and not passing the 30mm factory marking. The rest of the body doesnt seem to be adjustable. It is way too low. Is this normal?
Old Jul 1, 2013 | 09:28 AM
TheBoz's Avatar
remove both of the rears, set them up exactly the same on the ground, then reinstall. If it is still off, you might have missed a part. Check to make sure that everything is the same for both struts.
Old Jul 5, 2013 | 10:30 AM
WRC-LVR's Avatar
I seem to recall the oldr Evo 4-6 had a different top hat on the rears. If you got CT9a ones then the top hats might need swapping out.
Old Jul 6, 2013 | 09:47 PM
dominicsia's Avatar
Now thats weird mine don need to mod any stuff. like Pnp. only the rear is giving me tonnes of prob. i have send out the bottom part and ask a comp to help me cnc a new bottom end with 35mm increase in length
Old Jul 7, 2013 | 12:16 AM
Blue91lx's Avatar
There are also two different clevises. One has a spacer (welded, making it longer) and one doesn't. Doubt that's your issue, but figured I'd mention it.
GSRSpeedDemon
Jun 20, 2017 11:10 AM
TypeR31
May 2, 2016 06:20 PM
muster
Jan 30, 2016 09:08 PM
pennies_hatchie
20
Jul 31, 2015 12:20 PM
Meathooker
12
Sep 3, 2011 11:36 PM
