DIY wheel alignment kits?
Old Aug 22, 2013 | 01:36 PM
Construct's Avatar
Originally Posted by mithrandir7533
I went with Firestone Lifetime Alignment plan for $175 and have gotten my money's worth. I have it checked every time I go to the track.
Best thing to do is get friendly with the guys that do it and just join them when they do the work. Alignment is tricky no matter what. I've seen the numbers change while they were tightening the bolts.
I went to all of the Firestone locations around here and asked if they could align my car to my specifications. All of them said no, they could only align to the manufacturer specifications.
Old Aug 22, 2013 | 06:52 PM
griceiv's Avatar
I use a smart camber gauge(but any digital level should work fine) and long acre toe plates. making sure the alignment marks are equal side to side in the rear and the length of visible threads are equal on the steering rack gives me zero thrust angle quite reliably.
Old Aug 22, 2013 | 07:04 PM
WRC-LVR's Avatar
Originally Posted by nollij
My Longacre 3 prong doesn't stick in the wheel very well. I have to hold it typically. Not sure if I am just not doing it right. No matter how hard I try to jam it on there, it just pops off at the slightest inclination.
Short bungee cords from the back of the wheel work to hold it in place as does duct tape from the wheel spokes.
Old Aug 23, 2013 | 09:22 AM
Construct's Avatar
I'll have to try counting the threads and matching the alignment marks next time. That's a great tip, and it would certainly be much faster than setting up the strings each time.
Old Aug 23, 2013 | 10:19 AM
nollij's Avatar
Wonder why I didn't think of that.
Old Aug 23, 2013 | 02:02 PM
WRC-LVR's Avatar
Take it to a shop that caters to the autox crowd or SCCA track guys. Lots of body shops have both frame jigs and full alignment racks. Before you go ask them if they will align to your specs.
Old Aug 23, 2013 | 02:20 PM
WRC-LVR's Avatar
Originally Posted by mrfred
That was my initial action, but after three trips to the same alignment shop in about three months, its still pulling slightly to the left, and on the most recent trip, all the camber angles were shifted by about 0.4 deg compared to the previous visit despite no changes to the suspension. I've had similar experiences at other shops, so I've come to the conclusion that even with best efforts by the technicians, alignment is only as good as the quality and level of calibration of the equipment. I'm feeling like I need to take things into my own hands to make it right.
Swap one of the front tires to the rear. If the pull goes away, then the issue is with that one tire. If not swap the other front to the rear and see if the pull goes away. If it does go away now then the second tire is the issue. If it does not go away after both being swapped, then check the front left caliper for hanging/dragging. If it rotates as freely as the right, then you have an alignment issue. Check the thrust angle first. If the rear toe is not set properly, most likely both rear tires are pointing to the right slightly. Have them set both rear sides to zero relative to the fronts.. If that doesnt fix it then make sure they check the toe on the front and that the steering is properly centered. Although most modern rack and pinion steering systems are self centering, if the rack steering arms are not adjusted to the correct length, the rack might not be centering properly. That will show up in it wanting to move one way or the other consequently steering the car to one side. In this case the rack steering arms moves slightly to the right causing the car to steer slightly to the left.
LMK
Milburn
Old Aug 27, 2013 | 04:34 PM
03whitegsr's Avatar
Just picked up a Longacre digital caster/camber guage and the HD toe plates. I'm going to build up my own "smart strings" setup to dial in toe in the garage and then plan on using the toe plates if I want to make quick toe changes at an event.
If I could come up with a cheap corner scale setup, I'd be in business.
Old Aug 27, 2013 | 06:30 PM
WRC-LVR's Avatar
http://www.usa7s.net/vb/showthread.php?t=1300
http://robrobinette.com/corner_weight.htm how to do corner weighting
check them 2 links out. You can send the $$ saved to my EVO needs a TRE diff fund ;-)
l8r
Old Aug 27, 2013 | 08:11 PM
barneyb's Avatar
Years ago I was driving a '79 Pontiac TA. About every six month the tires would show abnormal wear and I would go in for another alignment. I figured that this was just the way suspensions are - always getting out of adjustment.
One day I took the afternoon off from work for an alignment shop appointment but when I arrived they were closed for a funeral. I called around but no other place could get me in that day. So, I stopped at a parts house and bought some shims - my car used shims for alignment.
I just used whatever measuring tools I had around the garage. Suddenly my car drove great, the tires didn't wear funny anymore. I didn't need to align the front end again until years later when I replaced the bushings and ball joints.
The moral of the story is that the alignment shops with their fancy machines do crummy work. Remember, most of these places sell tires.
Old Aug 27, 2013 | 10:59 PM
ace004's Avatar
About the firestone lifetime alignment... I used to work for firestone and yes they are only suppose to align it to factory specs. Doesn't count for aftermarket adjustments/ customs specs. I used to align my buddies car a couple of times before he went to the track and I hooked him up with his specs, but my manager was the only guy I knew who would let that happen. Either way a word of advice for anyone doing an alignment at a shop, watch them. if the technician can get away with minimal adjustments they will. I have also seen faking adjustments, which is easy to do.
Old Aug 28, 2013 | 09:05 AM
Construct's Avatar
Let us know how the Longacre caster/camber gauge works out. Also, I'd love to see pictures of your strings setup.
Old Aug 28, 2013 | 02:49 PM
st0k3d's Avatar
I feel like if I try this I will screw everything up royally.
Old Aug 28, 2013 | 08:41 PM
barneyb's Avatar
DIY alignment is hard. Working on engines is hard. Doing body work is hard. The thing with DIY alignment is that most of the hard stuff has to happen inside your head. Let me give you an example:
I figured out how measure toe. Then I figured out how to measure camber. But on the car I first aligned caster was also adjustable and changing camber also changed caster. With no caster gauge - how to measure caster? Well, when the steering wheel is turned and the front wheels are cocked, camber changes. The amount camber changes when you do this tells you caster. The rest is measurements and math.
Old Aug 29, 2013 | 12:11 PM
03whitegsr's Avatar
l8r
I had considered the bathroom scale idea, but it doesn't seem realistic on an EVO due to the weight. Also I wouldn't trust a spring scale at all so it would need digital scales. $30 a scale and 12 scales to handle the weight means $360 in scales. I've seen used Longacre scale sets go for $500. Seems worth the extra $140.
An alternative version of this is to use some A-beam lever arms. One side pivots on the ground, the other rests on a bathroom scale. The tire sits close to the pivot side so you end up with a lever arm setup. At 4:1, the lever arm setup and bathroom scale can measure about 1300 pounds per wheel with one scale per wheel. There is a guy on ebay selling lever arm setups like this. I just wonder how accurate they are as it seems like where the tire sits and camber setting could skew the results.
EDIT: Guess I should read the whole thread...ha
On that second link, he has some bad data in one boxes where he says he's gone too far. He has the left rear as 678 pounds when it should clearly be 778. The car was actually perfectly 50.0% cross weight at that point. Worth the quick read though just to see how many adjustments he had to make to even things out.
