Electric brake coolers
I looked around and couldn't find anything in the 2 inch range for front brake cooling fans instead of running ducts. I saw a car that had a similar setup not sure if it was 2 1/4 or 2 1/2, but 3 inch for sure wouldn't work. Is there a kit out there or is it all custom?
From: Driving ten under in the passing lane, right turn signal on at all times.
Are you overheating your brakes on a regular basis?
If you aren't, you don't need or want to cool.your brakes further.
Sorry big F1 fan here... Go Vettel GO!!!
I'm pretty sure F1 only uses fans when the car is stationary. I've seen the teams even put tape over the duct to keep heat in the brakes. And if they need to they peel the tape off. I'm sure the aerodynamicists dont like the tape
To the op, why the desire to cool your brakes with electric fans? Instead of the extra wiring and clutter why not just install a set of brake ducts? At speed I find it hard to believe a little fan would be able to flow as much air as a proper ducting setup anyway.
agreed
Seen it work great on a track car that went to english racing, unfortunately they didn't build the setup so they couldn't direct me.
I like factory oil cooler ducting, I dont want to compromise on the sleeper look. As a car that can serve dual duty I dont want to be taking ducts on and off for track days, rather flip a switch.
^Haha amen to that brother
How/where would you mount the fans? They would have to be huge or really close to the caliper to move enough air for adequate cooling.
Would you try and get a smaller inline fan and mount it at the end of a caliper nozzle or something?
silverevo05
12
Sep 3, 2010 05:45 AM
chet
16
Oct 16, 2007 02:28 PM
