Will these fit properly?
Old Oct 16, 2013 | 05:12 PM
tsitalon1's Avatar
On an Evo IX
http://www.discounttiredirect.com/di...=Car%2FMinivan
Old Oct 16, 2013 | 05:34 PM
evobros's Avatar
Yes they will! Google the wheels on the car. U mite need a rear fender roll depending on the tire size u go with.
Old Oct 16, 2013 | 05:55 PM
tsitalon1's Avatar
Which will fit better:
18X9.5 5-114.3 Offset of 15.
or
18X9 5-114.3 Offset of 30
I do not want to roll my fenders.
Old Oct 16, 2013 | 06:41 PM
or
The +15 dont fit. Yes, some run them w/the super stretch tire & roll in out of spec camber but that doesnt work, at least in my book. I understand the want for the super poke but its at the expense of proper fit
Run moderate camber (like a +30) & shoe them w/some wide rubber. Get the rear fender work for a zero rub fit on stockish camber
Old Oct 17, 2013 | 04:49 AM
tsitalon1's Avatar
Confused me with the camber references..
So get the 18x9 +30 for proper fit?
Will I need to deviate from factory alignment specs, especially with swift springs?
Sorry for the newbie questions, I'm not very versed in wheel/tire information.
Old Oct 17, 2013 | 05:29 AM
The so called "Stance" crowd will do anything to make a low offset wheel fit including adding large amounts of negative camber. By tilting the top of the wheel inboard to the mid-line of the car it helps in fitment but is terrible for handling
In not here to call out the spec wheel you should get but an 18x9 +30 is a solid, modest spec for the EVO. Even a +30 with a wide tire will cause you to modify the rear fenders. As an example I run 2 different offsets +29 & +30. Both set-ups have required my rear to be fully modded & I run a relatively aggressive 275/40 (roll, pull, bumper bolt & a few other things)
So, Your tire choice & offset will dictate how much fender work is required. Heres a pic I use in the fitment thread that really tells all. The rear tire must articulate fully in the well w/out any contact
Old Oct 17, 2013 | 07:41 AM
tsitalon1's Avatar
In not here to call out the spec wheel you should get but an 18x9 +30 is aa solid, modest spec for the EVO. Even a +30 with a wide tire will cause you to modify the rear fenders. As an example I run 2 different offsets +29 & +30. Both set-ups have required my rear to be fully modded & I run a relatively aggressive 275/40 (roll, pull, bumper bolt & a few other things)
Thank you for spelling it out for me.
So for someone who doesn't want to mess around with fender modifications, what would be a proper tire size for the 18x9 +30 wheel?
Or do I need to abandon the idea of using this wheel?
I've built countless motors and trannies, just never got around to "rolling fenders" so I'm unsure how difficult it would be. I do not want to damage the appearance of the vehicle in any way.
Old Oct 17, 2013 | 09:45 AM
You might want to consider a 255/35/18 or the 245. It might clear w/out any mods. The 255/40 would look so much better but its a much larger tire in circumference.
If you have a reputable body shop roll your fenders you should be OK. Dont have the shop tell you they cut vs roll. Rolling can split the paint but just needs to be sanded & touched up.
Just like its Ok to mod your motor / tranny, its Ok to mod the fenders
Old Oct 17, 2013 | 03:16 PM
tsitalon1's Avatar
Would 245/40/18 be a good compromise and fit without any fender modification on a 18x9 +30 wheel?
Old Oct 17, 2013 | 03:40 PM
evobros's Avatar
He has an X so they will fit joe. But duck if the +30 fit evos never seen anyone with them.
Old Oct 17, 2013 | 03:43 PM
tsitalon1's Avatar
Sorry, no it's for an Evo IX.
Old Oct 17, 2013 | 04:49 PM
tsitalon1's Avatar
nvr mind
Old Oct 17, 2013 | 05:21 PM
You guys are confusing me
After looking at the calculator again w/the 245/40 I think its going to be close, meaning a roll is likely (just my opinion)
Was hoping that you will change your mind regarding the fender roll. The EVO wells are a bit tight for the lower offsets
Old Oct 18, 2013 | 03:05 AM
tsitalon1's Avatar
Sorry about that!
So like an idiot, I've just now found the calculator at the top of the page.
If the stock wheel/tire package is indeed 17x8 in 235/45/17 +35, then it would appear that the closest package in a 18" size would be a 18x9 in 255/35/18 +30 which would actually decrease tire diameter by .3", lose 7.7mm of inner clearance and extend the lip of the rim 17.7mm outward.
I think I can live with that, even if some slight fender rolling is necessary with a wooden baseball bat
My only concern would be ride quality, I'm not sure how livable a 35 series tire will be on swift springs!!
Lil Evolution X
Nov 29, 2015 08:51 PM
missmyfdevo8
Dec 29, 2013 05:16 PM
fazzy98
Middle East Forum
Mar 4, 2008 03:10 AM
mitsuman6
Jun 16, 2005 11:34 AM
EVONation
Feb 25, 2005 10:33 AM
