XXR Right Size
Old Feb 20, 2014 | 10:12 AM
Justindexter's Avatar
XXR Right Size
So I am thinking about piciking up some XXR 527's in Chormanium Black. Specs are 18x9.75 +20mm. I was wondering what would be a good tire size for these. i know zero about tires so i am clueless on what to get. My car is lowered so I assume I might have to roll the back at the very least. Any advice is appreciated. Thanks ahead of time
Old Feb 20, 2014 | 10:26 AM
rjfg's Avatar
Onwhich model evo?
I run a 235 on my 17x9.75 and I have a nice snall stretch nothing "hella stretchex" but nixe
Old Feb 20, 2014 | 10:31 AM
bphx123's Avatar
proper tire size on that wheel should be 275/35/18 but you can slide with 265/35/18. Hope this helps.
Old Feb 20, 2014 | 10:58 AM
265? Would that be like a direct fitment. I see a lot of people running 245's with this setup. which one is a bigger tire
Old Feb 20, 2014 | 11:57 AM
llDemonll's Avatar
you might want to start reading about tire profiles if you don't know which is larger between a 265 and 245.
with no roll or pull in the back you'd need like a 225 tire to not rub
Old Feb 20, 2014 | 12:27 PM
bphx123's Avatar
265 is a wider tire than 245. Sure you can run 245 but you're tires are going to be stretched, not too safe
GinuwineEvo8
Apr 23, 2015 07:59 PM
rowynntrinidad
13
Oct 19, 2014 05:55 PM
ReBoosted
Apr 10, 2012 08:18 AM
EVO_SE
Dec 14, 2011 02:06 PM
sxmdaniel
Feb 16, 2009 08:09 AM
