Rear Hub Removal Question
Old Mar 8, 2014 | 07:25 PM
OneCrazykid's Avatar
Ok the hub is free and is just being held on by rust in the splines. The axle splines are holding the hub on. I tried beating it a bite to no avail. My question is will heating the axle/spline area damage the bearing? I don't plan to heat the unholy crap out of it but is this a bad idea?
Old Mar 9, 2014 | 12:42 AM
AndyCT9W's Avatar
Gear puller with the opposing force on the axle.
Old Mar 9, 2014 | 06:58 AM
Ag4G63's Avatar
So the axle is still in the hub? If so it is a lot easier to remove the hub if you remove the axle first. With the axle still in you will have to remove the hub completely straight which is difficult. If you want to do it that way use a puller as recommended above.
Every time I have removed one I soaked it all in pb blaster, pulled the axle, and then beat the hub off with a hammer equally all the way around. Never had a problem. Heat can help, but I have never needed it. Just don't melt any sensors.
Old Mar 9, 2014 | 06:14 PM
Thanks for the input guys I got it all done.
Old Mar 10, 2014 | 07:34 PM
AndyCT9W's Avatar
No problem.
How did you get there in the end?
Old Mar 11, 2014 | 03:29 AM
Originally Posted by AndyCT9W
No problem.
A little heat and pen oil
way2qik
246
Jul 10, 2019 11:28 AM
jeg5263
Lancer Tranny/Drivetrain Tech
Mar 6, 2016 07:50 PM
CeliOnce
Feb 3, 2016 11:53 AM
EVOLex
13
Oct 12, 2014 05:24 PM
bryonboals
14
May 27, 2014 12:23 PM
