Help with excessive tire wear
Old Mar 12, 2014 | 09:59 AM
aggieEVO's Avatar
I have the printout.
I'm guessing it's the way the bolts are flipped. I may flip them and go in for another check.
I'm going to get under there again and see what's going on.
Originally Posted by sujinX
u said the first alignment they got it right. what did the printout say?
this time u went in and its only -.8 up front, what happened?
when u did the ball joints was this before or after the initial "supposedly -1.5 up front and 0 toe" ?
-1.5 wont cause that wear, -2 on my car doesnt even do that even with autox.
the toe is pretty good from what u wrote.
im thinking something might be loose.
Old Mar 12, 2014 | 11:22 AM
Raptord's Avatar
Yes you flip the eccentric camber bolts to adjust camber. You get about -.9 on one setting and -1.8 on the other.
Old Mar 18, 2014 | 06:27 PM
aggieEVO's Avatar
So, I changed my outer tie rod ends tonight. Easy enough.
I was also going to change my inners, but I couldn't find the tool to loosen them.
One thing I noticed, from the passenger's side, I could see the yellow D-shaped bushing between the steering rack and the subframe from the Whiteline steering precision kit. Maybe I had overtorqued it when I installed it, but it was no longer properly oriented. I managed to loosen the bolts and straighten the bushing. Then tightened it back down. Wonder if that could have made a difference.
I'll go in for an alignment check tomorrow.
I also flipped my camber bolts. Interested to see what that gives me.
Old Mar 25, 2014 | 09:10 AM
cfdfireman1's Avatar
There is more to be had than with just flipping the bolts. You can load the suspension with the bolts lose or even use a good size pry bar and or move the top mounts some to get exactly what you want for camber.
aggieEVO what kind of numbers did you end up with?
Old Mar 25, 2014 | 09:32 AM
aggieEVO's Avatar
1.6 on one side, 1.5 on the other, I think. That is plenty for my daily driving.
Toe was 0 up front. They didn't listen and put toe to factory spec back in the rear. I'll have them change it back to 0 after I install my bump steer correction.
I put in new tie rod ends. Hopefully they do the trick. I went to do my inners but Autozone didn't have the right tool for rent.
Old Mar 25, 2014 | 09:45 AM
meckert's Avatar
One other item to keep in mind is that the alignment machine they have needs to be calibrated and the heads need to be in good shape. If they drop the heads or havent had the system calibrated in a while that would and could lead to settings that are way off--but could show to be rt on. May want to look at another shop-- since they dont really seem to be listening to your specific requests anyway-- just my .02. GL
Old Dec 8, 2014 | 09:10 AM
detroit evo's Avatar
You can find the inner tie rod tools at Harbor Freight or rented at Advance Auto Parts.
So far at 100k and some hard driving miles and a year + of rallycross that I have had to replace 3 inner tie rods. They are hard to get too but not impossible. Mostly flattening the lock washer with a hammer and some blunt tool causes most of my grief.
I found that the inner tie rod failure can cause that tire wear you were showing. Also on another occasion I had the rear bearing/bushing combo of the lower control arm break loose in the control arm. Worth having someone look at those too.
Old Dec 8, 2014 | 09:23 AM
aggieEVO's Avatar
Thanks for the reply.
I replaced my inners (although they were still in good shape with no play). I had the car aligned nicely with the camber bolts set to the aggressive setting. I think it was about -1.5. I rotated my tires after about 5000 and had some inner wear. Given that I drive the car about 60 miles a day lately, I went ahead and set it on the other setting. Unfortunately, I should have taken it in for an alignment right after. I destroyed my almost new front tires again. I had -.7 degrees of toe. Ouch.
My rears are still very meaty. I'm going to order another pair and not touch it for a while. Too many other things to do.
aggieEVO
Jul 4, 2016 08:32 PM
turbotaloon95
Jan 23, 2015 06:48 PM
jeffo24
24
Jun 24, 2012 04:17 PM
bigben
Dec 21, 2010 08:02 AM
onyx1121
31
Dec 26, 2009 02:20 PM
