Whiteline RSB - Clearance?
I installed the 24mm whiteline RSB today with stock mounts. It seems pretty darn tight. is this typical for this install, or do I need different mounts?
I don't hear anything banging around when I am driving even tripod, just looks really tight.
Thanks!
Thanks!
Correct, I've got the Perrin(Progress) 25mm RSB and it too is tucked right up in there. I believe it does indeed make contact but doesnt clunk or get hung up on anything so I never saw an issue and it's been on for like 6 years now...
And yeah dont forget to tighten that nut! Were you realigning the car or something? Not sure why its loose in the first place...
Thanks for the reassurances.
I tightened that nut. I had a hell of a time getting the larger sway bar in so i loosened that arm to move it out of the way, marked the eccentric bolt so its not too off, but will be aligning in a couple days anyways.
RABYRAB
Aug 3, 2013 05:58 PM
Pr3z
Apr 14, 2011 07:06 PM
