Girodisc problem help
Old Jan 2, 2015 | 02:26 PM
EvO-LOui's Avatar
So I just received my 2 pcs rotors front and rear for my 2006 lancer Evo. these are my second set on my second Evo . I'm having a problem with them .I just installed them and I'm getting a clunking noise as I press on the brake pedal car stops properly. now I had no problem with the first set I installed on my Evo only difference is I'm running the magic pads this time around on my last set I used ferodo 2500 pads an trimmed the rear pads for Clarence and I use the shims. so I'm pretty much at a dead end on what it could be I'm using magic pads which already come with the shims or am I require to buy additional shims?not sure what else I rechecked everything once again everything looks fine what could it be ?
Old Jan 2, 2015 | 04:21 PM
If the rotor is seated correctly & the caliper is torqued properly I dont see how this could be a pad or rotor issue
These kinds of issues are very hard to diagnose on the net. If you havent, pull the wheels off & inspect all, including suspension components (possible loose strut?)
Old Jan 2, 2015 | 04:42 PM
EvO-LOui's Avatar
I hear you it's hard to tell I've checked everything even removed a re did it and sounds like the pads a loose but rotors an are seated well before I installed the calipers I used three outta five lugs to hold rotors in place even grease the pads I don't know just thought some might had experienced this and I'm getting the noise on all four didn't have this noise before installing them
Old Jan 5, 2015 | 06:41 AM
EvO-LOui's Avatar
Problem fixed 👍👍
Old Jan 5, 2015 | 06:43 AM
e_kobz's Avatar
Originally Posted by EvO-LOui
Problem fixed 👍👍
What was the issue?
Old Feb 2, 2015 | 06:49 PM
EvO-LOui's Avatar
Originally Posted by e_kobz
What was the issue?
Simple fix just need to bond the pad on to the rotor . on normal stops noise went away as I use it more .it's a own issues at giro disc mike at giro disc was very helpful
EvO-LOui
Feb 2, 2015 06:50 PM
Girodisc Martin
Evo 'For Sale' Suspension / Brakes / Handling
40
Oct 11, 2013 09:40 AM
Girodisc Martin
86
Nov 9, 2012 03:20 PM
KK
59
Dec 16, 2005 05:15 PM
big_clints_evo
Aug 17, 2005 07:18 AM
