Wheel spacers for Evo V?
Old May 28, 2015 | 04:33 PM
Travisgod's Avatar
Hey there, Was just curious on what size mm spacers Id need too make stock rim/tires on my 1998 Evo 5 stick out flush with the fender, if not maybe stick out a little more than that?
Thanks,
Old May 28, 2015 | 08:06 PM
Evogun's Avatar
Just measure the depth now using a plumb and add what ever you want to get the look. Many places to get them H&R Kics ebay(be careful what you buy)etc.. all make spacers from 1mm-40+mm. Reason is it depends on the tires your running, they all fit different because of rim or no rim protection.
You may have to roll your inner fenders depending on how low you car is.
Old Jun 1, 2015 | 05:05 PM
Dave123456789's Avatar
use a plumbers bob (or a weight on some string) on the edge of the fender, measure face of wheel to the hanging weight and that's the size you need. bear in mind you may need to roll fronts and cuts out the plastic in the rear as you cant roll them.
cheers
Old Jun 3, 2015 | 04:09 AM
HYYBR3D's Avatar
Getting flush fitment is a pain with 5 & 6 and the rear flairs. There's no room to move unless you raise it up or run super stretched. I am using spacers but have ordered wider wheels to fill.
What size and offset are you using atm?
jgray2010
Oct 26, 2011 03:06 PM
evil6remlin
Jul 31, 2011 04:33 PM
R/TErnie
Northwest Region
Aug 14, 2009 09:08 AM
silverghost
Mar 1, 2007 10:46 AM
dannykao
33
Feb 25, 2007 06:29 PM
