front camber adjustment
Old Dec 3, 2015 | 04:13 PM
Jonno99's Avatar
Just a question, in the pics of camber adjustment you can either adjust the offset bolt in or out as in two settings only, but can you adjust it half way for incremental steps?
https://i.imgur.com/gQ44j86.jpg
Old Dec 3, 2015 | 05:55 PM
kaj's Avatar
kaj
yes, the bolt spins from one point to the other. rotate it to get the camber setting you need.
Old Dec 5, 2015 | 08:13 AM
RJones's Avatar
Assuming you're talking about the stock bolt: No, you can only adjust the stock bolt one way or the other. There aren't any incremental adjustments.
Old Dec 5, 2015 | 08:17 AM
kaj's Avatar
kaj
really? it's been a while, but i could swear mine had some adjustment. otherwise we'd be stuck with having to choose one of two camber settings only.
Old Dec 5, 2015 | 08:54 AM
RJones's Avatar
It's been a while for me too, but that's what I remember.
Old Dec 5, 2015 | 09:15 AM
Jonno99's Avatar
So I just did it and yes, the stock bolt has a cut out on the top and bottom which makes the bolt only be able to be turned out or in, the arrow on the bolt was pointing in which is what I thought it was so I turned it out which means now while I've stopped tracking in summer will save the inside of my tyres, I took it for a run and noticed it turns a little sharper but tends to push the front out a bit in sharp corners, I can live with that and I'll turn it back when I start tracking again, but the way the bolt was damn tight, had white thread locker on it, I had to use a flame torch to loosen it, the bottom one I could just do it with a long bar, make sure you use a 6 point socket too otherwise you'll damage the bolt trying to loosen it
Old Dec 5, 2015 | 09:20 AM
kaj's Avatar
kaj
yeah, the torque for those bolts is kinda high. also, you may wanna check your toe settings. the camber change may be enough to affect the toe enough to need a touch up.
SlowSRT03
Jun 2, 2012 07:05 PM
rallykid
Sep 14, 2010 07:37 PM
CO_VR4
Sep 4, 2009 01:48 PM
jd888jd
Jul 23, 2009 07:50 AM
97itr153
May 13, 2003 12:16 PM
