Brake Noise
Brake Noise
I replaced my pads and rotors with centric rotors and stop tech street pads about a week ago. Brakes work perfect but they'res a lot of grinding noise and it's loud. Anybody dealt with this?
Did you bed the brakes in properly / Are you using the OEM shims? / Did you clean the rotors before installing
There are many factors, I just noted a few. Running the non OEM shims in the rear was a serious noise maker for me
I thought the most common question was why is my brakes sqealing lol, but anyway, all of the above clean brakes thoroughly, seat pads in correctly, shim set up correct, I use a thin smear of copper ease on the pins and back of pads, between Shims and pistons, seems to keep them quiet for me. also make sure both pistons are free and pushing down evenly on pad ie inspect pad wear
One the most frequent questions posted in this section
DrivelineSales
EvoX 'For Sale' Suspension / Brakes / Handling
Nov 5, 2009 03:40 PM
DrivelineSales
Evo 'For Sale' Suspension / Brakes / Handling
Sep 24, 2009 01:04 PM
Fizz Autosports
124
Sep 14, 2009 07:26 AM
DaWorstPlaya
Oct 21, 2008 09:47 AM
