Dimensions of stock rotors???
Hi guys,
Does anyone know the dimensions of the stock front and rear rotors on our cars? I'm working with Wilwood to put together a floating rotor package for the Evo that would work with the stock calipers. Wilwood has a nice variety of rotor surfaces available (look here for pics) and they'd be easy to swap back and forth once we have proper hats.
Specifically, I'd need to know:
rotor width (thickness)
rotor diameter
hat diameter
hat depth
Can anyone here help me out or point me in the right direction? Thanks in advance!
Emre
rotor diameter
hat diameter
hat depth
Emre
Originally posted by rhyzin
front
320mm diameter
32mm thick (29.8mm min thickness)
43.5mm total height
rear
300mm diameter
22mm thick (20mm min thickness)
58mm total height
front
320mm diameter
43.5mm total height
rear
300mm diameter
58mm total height
Kayaalp,
Wilwood may already have something....
http://www.socalevo.net/forums/viewt...ighlight=rotor
Stock rotor weights.
Front 20.9lbs.
Rear 14.7lbs.
Link for other misc. weights.
http://www.socalevo.net/forums/viewtopic.php?t=379
Front 20.9lbs.
Rear 14.7lbs.
Originally Posted by rhyzin
front
320mm diameter
43.5mm total height
rear
300mm diameter
58mm total height
320mm diameter
43.5mm total height
rear
300mm diameter
58mm total height
Front brakes
Type: 4-opposed piston, ventilated disc
Disc effective dia. thickness mm (in): 263 - 32 (10.4 - 1.3)
Wheel cylinder I.D. mm (in): 40.0 (1.58) - 2, 46.0 (1.81) - 2
Pad thickness mm (in): 10.0 (0.39)
Clearance adjustment: Automatic
Rear brakes
Type: 2-opposed piston, ventilated disc
Disc effective dia. thickness mm (in): 252 - 22 (9.9 - 0.9)
Pad thickness mm (in): 9.0 (0.35)
bakuro117
For Sale - Wheels / Tires / Suspension / Brakes
May 8, 2017 02:25 PM
LANEVO creazy
Mar 17, 2016 10:09 PM
STM Tuned
Evo 'For Sale' Suspension / Brakes / Handling
19
Feb 8, 2016 06:32 AM
Vivid Racing
Feb 6, 2012 04:39 PM
