Varrstoen MK5 Wheels
http://www.varrstoen.com/product/mk5...-5x114-3-73-1/
Has anybody tried these or know if they clear the brembos? If not what kind of spacers should I be thinking about and will i need to roll or pull the fenders? I've searched plenty but haven't seen anybody running these.
18x10 +25? LOL yes you'll need to roll and extensively pull the fenders and relocate the rear bumper bolt
you'll also need new hubcentric spacers to properly keep the wheel centered
18x10 +25 running a modest 275/30 tire. Very difficult to fit correctly. Too much rear fender work required & would not be pleasing to look at
Not recommended due to the 10" width combined w/the +25. Some 10" wheels work, this one does not
I don't know why but wheel fitment is just one of those things I can't wrap my head around. Does offset make more of a difference in clearing the brakes or fitting under the fenders? So with a wheel like the ES8: http://www.varrstoen.com/product-category/es8-sale/
a lower offset like the +12 or +22 would fit better than the +30 or +35 but still may not clear the brakes...
Lower offest (+12 or +25) wheels are tougher to fit on the stock body EVO vs a +30 to +38 wheel
Caliper clearance is based off of spoke design (concaveness). But, lower offset wheels (i.e. +12) do have a better chance of clearing the brakes than a +30 (positioned further outboard of centerline)
IMO the best bet for aggressive wheels is to make sure they fit in the rear fender.
Then use a spacer in the front as required to barely clear the calipers +3mm.
As stated, the spacer will really depend on the wheel design of the spoke, if it's even needed.
make sure you get the right offset...i was naive and relied on the vendor's advice and ended up with a wheel and tire that still didnt fit after rolling the fenders. What that equates to is every time the car dips the side body panel cuts into the tire. not a fun experience.
Speed Element
EvoX 'For Sale' Wheels / Tires
20
Sep 2, 2010 06:30 PM
Speed Element
36
Jun 25, 2010 11:01 AM
Speed Element
Evo 'For Sale' Wheels / Tires
40
Jun 18, 2010 10:44 AM
