Performance difference between 17 and 18 inch wheels?
what kind of difference is there in performance between the two? mainly concerning autocross and at the drag strip? how wide can i go with the 17s or 18s? are 19s too big? please provide helpful information. thanks!
If you do the plus 1 or plus 2 then it helps in handling b/c you have a short sidewall w/ the 18 or 19's but you can sacrfice ride quality in some instances.. The reason is less deflection of the sidewall or sidewall shift/roll so the vehicle handles better but since it is smaller it also makes the vehicle ride a little rougher, but that is minimal...
The only sideeffect is the added wieght that sometimes comes w/ going up in size but that can be minimal as well..
If you aren't hardcore then you might never notice a difference beside the aesthetic factory of bigger wheels and tires....
17s would be faster, 18's would be a larger diameter, so it would be that much harder to spin. Believe it or not 15 or 16 inch wheels would be optimal, but you can't fit a decent set of breaks on it.
EVO8LTW
Feb 23, 2008 11:39 AM
16, 17, 18, 18wheels, 19, anf, between17, didderence, difference, evos, inch, larger, mile, performance, wheels
