Tick Tick sound when making turns ???
Old Apr 6, 2004 | 03:31 PM
GOKOU's Avatar
I'm hearing a tick tick sound from the driver side when making sharp turns? Struts? It sounds like the axle is bad or something? Anyone else have this and how to get rid of it?
Thanks
Old Apr 6, 2004 | 05:28 PM
Shahul X's Avatar
have aftermarket springs?
Old Apr 6, 2004 | 08:16 PM
GOKOU's Avatar
Nope stock about 10K miles. I'm surprise no one have this problem.
Old Apr 6, 2004 | 08:51 PM
Axis of Evo's Avatar
Is it only after you've been driving at sustained speeds for a while, and when you are starting from a stop and turning at the same time? You may be hearing the clutches in the differential binding. That's a common thing in all AWD vehicles, and the more aggressive the setup the worse. After a long fast run on the highway mine does it pretty loud and you can almost feel it through the chassis. There are a bunch of threads about it.
Old Apr 6, 2004 | 08:53 PM
BJai02's Avatar
Check your CV. Check to see if the CV boots were damaged.
