Caliper rub on rotors..
Old Oct 5, 2018 | 04:14 PM
tkyang's Avatar
caliper rubs on rotors only on passenger outter side. pads still good. everything seems tight. could it be the piston? or piston boot?
Old Oct 5, 2018 | 04:17 PM
What rotor part no. was installed? Assuming this is an EvO 8/9?
A little more info would be helpful. Was this rotor just installed? Whats the other side look like?
Old Oct 6, 2018 | 01:43 PM
tkyang's Avatar
Been driving fine for 10months. Its stoptech rotors for evo8. Just rubs on the outter rotor not the inner
Old Oct 6, 2018 | 02:02 PM
Both sides Driver / Pass? Brakes worn? dislodged? Pad pins not engaged? Caliper loose?
Old Oct 7, 2018 | 10:12 AM
tkyang's Avatar
Just the passenger side. I tried shaking the calipers but its on tight. Pads going in more than it suppose to that cause the touching of caliper and rotor. Guide pins looks straight. When i step on the brakes its fine but when i let go, it stratches the caliper
Old Oct 7, 2018 | 01:07 PM
Interesting! Well, sounds like the rotor spec is proper (proving both sides are the same?). Wonder if the Pass side brake pad is out of spec or damaged? I would have thought the pins would keep it from dropping down.
Have you tried loading in a new set of pads? That rotor looks damage beyond repair.
I would order up a pair of Centric rotors & some Stop Tech Street Perf pads ASAP
Heres an example: https://www.tirerack.com/brakes/brak...6&autoModClar=
Old Oct 8, 2018 | 11:22 PM
patric78's Avatar
I had a similar issue in the past (on another car), a tiny stone came within the pad and rotor while I was braking and remained stuck to the pad. time passed and after some time I had a similarly damaged rotor.
Old Oct 9, 2018 | 11:22 AM
barneyb's Avatar
If the two outside piston are stuck (wet fluid) could the inside pistons flex the rotor?
Old Oct 10, 2018 | 09:40 AM
tkyang's Avatar
Only when i press the brake pedal. But i think thats what happened. Pedal feels soft so i would have to pump ar least twice for a firm brake. Fluid is full but maybe theres air bubble in there. Should i just change the piston seals and brake flush? Imma gonna fix sometimes this weekend
Old Oct 10, 2018 | 10:44 AM
barneyb's Avatar
To check for frozen pistons, remove the master cylinder fill cap, pull the pads and see if you can lever the pistons into their bores. I just use the pad itself as a lever and my fingers. The pistons should move without a lot of effort.
Old Oct 10, 2018 | 04:06 PM
hutch959's Avatar
my bet is something not right on that side....
maybe the pad hung up on a shim or a stay.
maybe a rock...
maybe a stuck piston...
Old Oct 18, 2018 | 10:39 PM
tkyang's Avatar
Finally got to look more into it. It was the hub bearings! Failed the wiggle test but I swear it wasnt like this before. Not normally the symptom i would think of but replaced both side and its running good now.
Old Oct 19, 2018 | 05:02 AM
Thanks for updating & letting us know
