18x8.5 +35
Old Oct 8, 2019 | 03:52 PM
castro7's Avatar
18x8.5 +35
So I have a set of 18x8.5 +35 and they hit the brembos so I have a 25mm spacers and they work but the tiers hit the side skirt so cant do that then i found some basic spacers and they come to measure 8mm and both of them together make 16mm spacers. Put on the wheels and they clear the brembos by maybe 1/2mm and they dont hit my side skirt.
So what I am asking is want to see what kinds of setups you guys are running with that size wheel and offset.. tires right now are 225/40 18 but new tires going on are going to be 255/35 18 wheels are nt03.
Old Oct 8, 2019 | 04:11 PM
Yeah, that 25mm is a very large spacer & im not surprised they would cause an issue
Proper caliper clearance should be 3-4mm so be careful youre setup is not too close
Your tire choice of 255/35 is certainly OK. Rear clearance will be OK w/that +35 offset coupled w/the 8.5" width
Old Oct 8, 2019 | 04:28 PM
castro7's Avatar
Ok yea I know the 25mm is stupid but when i said 1/2mm i ment 1-2mm no 1/2mm lol sorry bout that u said 3-4mm is proper caliper clearance 1-2mm is a issue?
Old Oct 8, 2019 | 05:39 PM
Yeah, 1-2mm could be an issue if that wheel flexes hard under load. You can certainly try & run it & check for any rubbage. It might be OK
bnr34rb26dett
Jun 12, 2013 02:52 PM
crand002
For Sale - Wheels / Tires
16
Nov 3, 2010 10:54 PM
Justin Zingel
Oct 15, 2008 09:12 AM
06 SPOOoL
Sep 24, 2008 02:29 AM
DJ Brett B
10
Jan 5, 2008 11:58 AM
