cusco rear sway setting
hello i have just received my new cusco rear sway bar from Z1 Auto. Thanks Z1 for the great service !! I have an otherwise stock suspension and I am curious which hole people are using on the new bar. The inner, middle, or outermost hole? Any suggestions would be appreciated.
Try the middle hole first. Drive around a corner hard with someone watching you do this, if the rear inside tire lifts, reset in the last hole to the end. Most of the time with the stock setup the middle will be fine however.
