Tire pressure
Old May 12, 2004 | 06:02 AM
KZEVO's Avatar
Tire pressure
What front and rear tire pressure are people running for road course (track) events. Thanks!
Old May 12, 2004 | 09:59 AM
Bogie's Avatar
Advans--hot (I check pressures after a run): 42(f), 39(r). I start with about 36/37(f), 34/35(r) cold. I ran a couple of events on Goodyears, those tires were pumped to 49(f), 46(r). It depends on your tires and alignment settings, but after a session you should examine the sidewalls and see how they are scuffing or if they are rolling. If you are scuffing beyond the little roll indicator, add air.
Old May 12, 2004 | 10:29 AM
mayhem's Avatar
I use the same cold settings as Bogie. 36F 35R. You might even have to bleed off a pound or two after they get real hot.
Old May 12, 2004 | 12:56 PM
KZEVO's Avatar
thanks for the info guys. I was talking about OEM tires. I'll start with 36/35 and go from there.
Old May 12, 2004 | 01:16 PM
mayhem's Avatar
I was using the OEM Advans too.
Old May 12, 2004 | 01:36 PM
Kyperion's Avatar
Never tracked, but for AutoX my hot pressures are 41 front - 39 Rear on the stock advans.
Old May 12, 2004 | 05:56 PM
vicbdn's Avatar
Eh? I thought it was supposed to be 32/30....at least thats what the manual said... =\ =\
Old May 12, 2004 | 08:16 PM
WhosEVO's Avatar
read the first post and you will see ppl is asking what pressure to use at the TRACK.
when you goto the track, autox.....you need to pump up the tire pressure a little to prevent the sidewall from rolling.
I use 38f, 34r hot pressure in autox.
Old May 26, 2004 | 10:08 PM
A-SPEC's Avatar
I have ran Stock ADVANs, FALKEN Azenis and ADVAN 032R on varies tracks in Southern California, I found 34psi F & R COLD are about right for EVO and you might want to lower it a bit when the temperature getting very hot (i.e. summer time 100F+)
Hope these help.
Old May 27, 2004 | 05:53 AM
andyevo's Avatar
Arent you guy's running into problems with understeer with the rear tire pressure lower than the front?
Old May 27, 2004 | 09:12 AM
A-SPEC's Avatar
You can treak your car's setting to minimize the understeer. Such as, running more negative camber on the front wheels (2 degrees or more, with adjustable upper mount), and suspension tuning (stiffer rear shocks or springs), etc
Tire pressure is one of the area you can tune your car's handling, but I found 34psi is around the sweet spot on Evo's weight....
Old May 27, 2004 | 09:36 AM
ez76's Avatar
The front runs more pressure because there is more weight (~600lbs.) up there.
Old May 27, 2004 | 09:44 AM
TheGVR4kid's Avatar
I guess Ive got it all wrong, Ive been enjoying 38/40 on whatever crap alignment came from the factory.
Old May 27, 2004 | 11:31 AM
KZEVO's Avatar
I ran 36(F)/34(R) cold and found it to be fine a couple weeks back.
Old Jun 1, 2004 | 07:11 PM
thor's hammer's Avatar
highway tire pressure
Trying to soften up the ride to live with LA highways.
Will 32 psi mess up the stock tires?
