question about rotate tires!
hi guys
i am new to 4wd.
just want to know how to rotate the tires! can i change the wheel and tire or i have to let the tire shop to take the tires off then put them back on with no wheels changing?
sorry about the stupid question
thanks for the help
peng
i am new to 4wd.
thanks for the help
peng
Just rotate them front to back and keep them on the same side of the car because they are directional tires. Dont forget to re-adjust your pressure when your done. Its as simple as that.
wow
thanks for the quick reply guys
i heard people say u need to take the tires off the wheel and don't rotate the wheels......
anyway i will just take off the wheels and rotate them back to front
peng
peng
this doesnt deal with rotating tire but i read that ur new to the awd and i work in a tire shop so i thought i would let u know something very important. NEVER replace one tire, with an awd car the tread for all 4 tires must be very close in tread depth or u can blow out ur transfer case. just htought id let u know
Don't forget to torque down the lug nuts in a star pattern and w/ a torque wrench. Factory lug nut torque spec is 73 +/- 7 ft-lbs. Uneven lug nut torqing could lead to warped brake rotors.
