Quick Question After Installing TEIN-S Springs
Well, after installing tein-s springs on my evo and my brothers
evo, ive noticed that his wheels sits almost perfect in front mine, sits
on angle, yah i did an alignment is it possible that i screw
something up while installing front springs? meybe stock
shocks are bad allready also is it required
to have chamber kit in front with tein-s springs? if yes where can i buy
them and how much they go for Or where can i buy
front shocks? thx
front shocks? thx
by saying sit prefect / sit angel......sounds like to me you have more negative camber than he does. If you do the alignment at a shop they should gave you a print out and you can see the different.
you can check the alignment adjusted bolt (the top one which holding the shock) and see where is the "white arrow" point at. If it point to the motor=less negative camber, point outside = more camber.
hope this help.
hope this help.
