Stasis 2-Piece Floating Rotor
Old Jul 27, 2004 | 07:23 AM
  #31
propellerhead's Avatar
I'd like to see a long term test versus a series of canyon runs. I have a feeling that the Alcon rotor rings will tolerate more abuse and heat cycles than the factory rotors. Ryan at Stasis qouted a typical track life of 40 hours before the rings need replacing. I'd like to hear what kind of track life a set of stock rotors have in them. If it's significantly shorter, then these rotors are probably a practical upgrade since the replacement rotor rings are cheaper at $225 each versus the stock rotors at $240 each.
Two piece rotors are probably alot kinder to the front wheel bearings too resulting less bearing wear and reduced pad knock back. pad knock back was noted as an issue with the Subaru in the SCC article.
Old Jul 27, 2004 | 07:28 AM
  #32
meanmud's Avatar
We (consumers) should see these very soon - I will be calling Stasis today for an update. I think they were at customs a couple of weeks ago
Old Jul 27, 2004 | 07:46 AM
  #33
ru4real's Avatar
I read that SCC article and came away very impressed by the Stasis rotors. When I get an Evo, I'll be planning to upgrade to them with Ferodo DS2500 pads. You get better cooling on the inside diameter (should help the wheel bearings), lower disc replacement cost, and good looks.
Old Jul 27, 2004 | 07:49 AM
  #34
I called Stasis on 7/23 to check on status. Ryan mentioned that the Alcon hardware was in stock but the hats specific to the Evo were out getting anodized. He indicated 5 to 10 days before they start shipping.
Old Jul 27, 2004 | 08:10 AM
  #35
twan's Avatar
Maybe this will help. Scans of the SCC article I posted:
http://www.wtfbracing.com/forum/viewtopic.php?t=1255
Old Jul 27, 2004 | 08:56 AM
  #36
Keep in mind that the prices quoted in that article for the Stasis rotors are not correct. The price for EACH replacement Stasis rotor is $225, versus the $225 per pair as stated in the article.
Old Jul 27, 2004 | 09:33 AM
  #37
ru4real's Avatar
Originally Posted by propellerhead
Keep in mind that the prices quoted in that article for the Stasis rotors are not correct. The price for a pair of replacement Stasis rotors is $225 EACH, not $225 per pair as stated in the article.
You just said a pair is $225 each, the same thing as $225 per pair. Care to edit that? Do you mean each rotor is $225, so $450 per pair?
Old Jul 29, 2004 | 08:46 PM
  #38
Duh, yup. Editted, thanks.
Old Jul 30, 2004 | 12:34 PM
  #39
metaphysical's Avatar
Registered User
Hrm, I just thought of this. You pay 850 for the full front rotors, and when you burn them out you take the rotor apart and just replace the center part for $450. That's not too bad (still expensive).
Old Aug 5, 2004 | 11:07 AM
  #40
value's Avatar
That test was scary. STI brakes caught on fire
Old Aug 5, 2004 | 11:45 AM
  #41
mayhem's Avatar
So were they using DS3000 or 2500 pads on the STi? I also didn't like they're report on the 3000s on the street. Especially since you're not suppose to use them on the street.
Anyway, it sounds like it's best to just stick with the stock rotors. With the stock rotors they were getting an even heat distribution throughout the rotor. With the stasis the innside was cool, but the outside was sky high. This would put your pad in two different coefficient of friction levels. Sounds like the brake feel will become unpredictable at that point.
I'm sticking with the solid cast iron rotors.
Old Aug 5, 2004 | 01:09 PM
  #42
ru4real's Avatar
An advantage of the lower temp. on the inside diameter of the Stasis rotors will be that it is easier on the wheel bearings.
Old Aug 8, 2004 | 07:41 PM
  #43
infantsam's Avatar
2 piece rotors help wheel bearings because they insulate the rotor heat from the hub better....the hat doesn't get as much heat transfer...
But replacing the rings is not always a piece of cake. THe heat, dust,rust etc tends to make things a little sticky.
Old Aug 24, 2004 | 04:58 AM
  #44
meanmud's Avatar
Not sure, but
I think they're getting ready to ship these
Old Aug 26, 2004 | 10:24 AM
  #45
meanmud's Avatar
Credit Card
took a hit; they are on the way
