tire help
Old Jul 6, 2004 | 01:57 PM
Chris EVO 8's Avatar
tire help
I picked up a screw in my front tire and it went right through the side wall. I was told that this could not be fixed ( I'm ok with that ) but then they told me I had to replace all four tires because it was an all-wheel drive car. Is this guy feeding me a line or is it true? I have 5/32 of tire wear. I would be greatful for any help the forum can offer.
Old Jul 6, 2004 | 02:00 PM
EVOL 8's Avatar
If your tires aren't wearing bad... just get one. If questionable get 2. Don't get jacked!
Old Jul 6, 2004 | 02:01 PM
oak2207's Avatar
You don't have to replace all 4, especially if I'm reading that right and you barely have any treadwear. Now if you have somewhat worn tires it's a good idea to that way they will all wear the same, and that's what I did. It can cost ya, so it's really a personal choice. But just because it's AWD doesn't mean you have to, you just want the tires to all wear the same, and with 3 worn and 1 new tire, you'll never have them all wear the same again.
Old Jul 6, 2004 | 02:04 PM
f86sabre's Avatar
My understanding is that with AWD cars you would need to replace all 4. You would get a mismatch of velocities at the differential due the difference in diameter and this could cause undue wear on the dif. 5/32” is pretty deep wear for the Advans. I’m not entirely sure how much tread they came with when they were new.
Best wishes,
f86sabre
Old Jul 6, 2004 | 02:07 PM
EVOL 8's Avatar
Talking
If you replace all four, at least you will have 3 emergency spares.
Old Jul 6, 2004 | 02:19 PM
tswift's Avatar
Let me do a sales plug here. 5/32 is almost have worn out. I'm sure the Advans come at at least 8/32 possibley 10/32. For reasons given before, you need to make sure the new tire is the same depth because of the diferential. Goodyear has even put out a bulletin about this subject and the same thing has been written in the trade magazines.
Here is where I can help. I can order you a new A048 and we can shave the tire for you to match the other tires. Cost is $15 per tire. This way al the tires will be with in 1/32 or so which really makes no difference.
Pm me if you would like to discuss this more.
Old Jul 6, 2004 | 02:32 PM
machron1's Avatar
I'm no expert, but I'm fairly certain you can run disparately worn tires front to rear, but not side to side (especially with the rear LSD). I would get two new tires and put them on the front. Just plan on buying 2 more within the next few months because Advans wear fast. OR for about the same price as 2 Advans, you could get 4 brand new Falken Azenis Sport in 245/45/17. That's what I run and they are really nice. About as sticky as the Advans but not anywhere near the price. I got mine for $560 mounted balanced out the door with lifetime rotation & balance.
