Newb to this whole thing?
Old Jul 18, 2004 | 04:16 PM
Ariofighter's Avatar
I have recently finished my plans for the performance section of my evo, but now i want it to look good, if thats possible to make it look better.
So long story short, i want to lower the car alittle bit, enough to make the wheel gap smaller. However i have been warned by my friend that just throwing on new springs will wear my tires like three times faster, and i dont want that, is that true? So how can i go about lowering the car without destroying my tires or the comfort of the cars ride.
Also i dont know much about suspension so if any answer could be put in layment terms, or described to me, that would be great.
Old Jul 18, 2004 | 04:27 PM
NvsEvo's Avatar
lowering your cars with just springs does not damage your tires in any way, if you have them aligned properly.......
Old Jul 18, 2004 | 04:41 PM
so then i would need new springs and i would need to have my car aligned? Can you recommend a spring that i could buy? Also would they make the car ride really bad, a friend lowered his Srt-4 and he said it rides like ****, will the same thing happen to my evo?
Old Jul 18, 2004 | 04:54 PM
NvsEvo's Avatar
to my knowledge, Srt-4 already rides like sh*t... J/K.....but the ride feels about the same, except it got a little stiffer(which means better), and i got the S-Tech Teins on...
for spring, they have the nicest drop......
Old Jul 18, 2004 | 05:08 PM
James's Avatar
yes i agree, tein-s does have the nicest drop. about two in front and around 1 inch in the back. and its not that much money.
thats what i am getting ready to buy
later
Old Jul 18, 2004 | 05:17 PM
So what else do you need, or is it just the springs? Like i said i dont know much about this. Also isnt that a large drop, does your every day drivability suffer any? Having to slow to like 10 MPH to go over any bumps, does that get anoying?
Old Jul 18, 2004 | 05:53 PM
Cash Money's Avatar
def get an alignment after the install... could save you a bit of wear on the tires... An inch drop isn't that harsh on stock struts/shocks usually... I never had a problem with blowing them out... some other ppl i know, that dropped their car 2" or more had to replace their struts soon after as the more pressure on them caused them to leak... I'm not sure how well the stocks on the Evo would be in the long run, maybe someone else can tell you their experience...
Old Jul 19, 2004 | 05:41 PM
NvsEvo's Avatar
i have 4000 miles on those spring, and the struts still feel very strong.......and the only things i slow down for is a speed bump...my car is dail driven for everything.....never did scrape while driving.................
