Suspension vs Tires
Old Aug 10, 2004 | 10:02 PM
CanyonEvo's Avatar
Suspension vs Tires
hey guys,
i'm wanting to improve the turn-in and mid-corner grip for canyon driving (and maybe some track days) and was wondering which will give a better result... stock suspension (possibly lowered?) with RA-1's OR JIC/ZEAL coil-overs with stock Advans.
i already have RRE's rear sway bar, which is currently set to "soft" and i'm about to see what it's like in the "intermediate" position. if i went coil-overs i would get RRE or someone equally experienced to set it up for me.
so basically the question is will R-compound tires alone make more or less of a difference than a well set-up coil-over with stock tires.
obviously doing both would be ideal, but the money tree is running low...
thanks for any words of wisdom,
cheers,
warren
Old Aug 10, 2004 | 10:07 PM
Sentinal's Avatar
In most cases putting aftermarket suspension on the car actually hurts performance when it comes to cornering there are a few exeptions however the Evo's handling was designed very well stock and most people I know that have put aftermarket springs/coilovers on have regreted doing so. I would go with the RA-1's however the stock advan tires are also really good and the RA-1 performance will only be a slight bit better. I wouldn't expect huge suspension gains from either one or even both.
