Need help with Tein RA's
I recently purchased a set of these from a member on the board. However, I didn't get the instruction manual or tools to adjust them with. Does anyone have a copy of the instrustion manual in .pdf or know what I could use to adjust these?
Thanks for the help Brian |
no one?
call tein, or find a local dealer. i dont have a scanner, otherwise id send you the book..
thanks, anyone else?
bump
Hey mate
What you do need to adjust on the RA? The spring perch or the damping?
The biggest issue right now is coming up with the instruction manual. I was told that tein had this on their website, but the link is down right now.
But yes I will need to adjust the damping and the ride height. |
Link to the japanese version is here.
http://www.tein.co.jp/ti/ra/pr52.pdf Assembly is straight-forward enough, just follow the diagrams. Ride height and damping adjustments are on Page 9. You can figure out from the diagrams there regarding their recommended shock height and ride height settings. The recommended damping adjustment is 10 clicks front and 10 clicks rear. Let me know if you need help with anything else.
If only I could read japanese.... HA Thanks anyways
Nope the site isn't down, but the link to the manual for the RA's is inactive.
bump
bump
i have a set of ra also i call tein becuse the instruction manual is in japanese they told me to go to there site and view another sets instructions to put mine together
cool
| All times are GMT -7. The time now is 06:16 PM. |
