Need help with Tein RA's
I recently purchased a set of these from a member on the board. However, I didn't get the instruction manual or tools to adjust them with. Does anyone have a copy of the instrustion manual in .pdf or know what I could use to adjust these?
Thanks for the help
Brian
Thanks for the help
Brian
Hey mate
What you do need to adjust on the RA? The spring perch or the damping?
Thanks for the help
Brian
Thanks for the help
Brian
The biggest issue right now is coming up with the instruction manual. I was told that tein had this on their website, but the link is down right now.
But yes I will need to adjust the damping and the ride height.
Link to the japanese version is here.
http://www.tein.co.jp/ti/ra/pr52.pdf
Assembly is straight-forward enough, just follow the diagrams.
Ride height and damping adjustments are on Page 9.
You can figure out from the diagrams there regarding their recommended shock height and ride height settings.
The recommended damping adjustment is 10 clicks front and 10 clicks rear.
Let me know if you need help with anything else.
