-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   Tein Flex's Squeaking and driving me nutz! (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/196030-tein-flexs-squeaking-driving-me-nutz.html)
MrEvoVIII Apr 17, 2006 07:23 AM
How do you fix squeaking coming from your coilover's dampeners?!
I just installed the coilovers and there's this squeaking on quick bumps in the front
passenger side... I made sure everything was tight or torqued to specs.
The alignment shop said it was coming from the dampeners. I called Tein up and they said to give it a couple hundred miles for the shaft to lube up on its own. Anyone else experience this with their coilovers and is their a quick fix to this...?!!
Its really driving me nuts!
twinturbozs Apr 22, 2006 01:11 AM
Its a very common problem with Teins, i had that same problem with my Tein HA on my supra.
gsrboi80 Apr 22, 2006 07:31 PM
My TEIN SS I used to have on my Integra were squeeky as well
MrEvoVIII Apr 28, 2006 11:48 PM
That's not good to hear... Did it ever go away..?! b/c I wouldn't be able to put up
with it for too much longerr..
evo_dadi Apr 29, 2006 05:04 PM
put a little bit of silicone grease on the pillowball by the camber plates this usually helps.
MrEvoVIII May 23, 2006 08:45 PM
thanks for the suggestion!! this fixed it right up.. I actually put some heavy duty grease on the top and bottom of the pillowball mount plates... squeaked a few more times until the grease worked its way in I guess. Thanks again...
