Tein Flex's Squeaking and driving me nutz!
Old Apr 17, 2006 | 07:23 AM
MrEvoVIII's Avatar
How do you fix squeaking coming from your coilover's dampeners?!
I just installed the coilovers and there's this squeaking on quick bumps in the front
passenger side... I made sure everything was tight or torqued to specs.
The alignment shop said it was coming from the dampeners. I called Tein up and they said to give it a couple hundred miles for the shaft to lube up on its own. Anyone else experience this with their coilovers and is their a quick fix to this...?!!
Its really driving me nuts!
Old Apr 22, 2006 | 01:11 AM
twinturbozs's Avatar
Its a very common problem with Teins, i had that same problem with my Tein HA on my supra.
Old Apr 22, 2006 | 07:31 PM
gsrboi80's Avatar
My TEIN SS I used to have on my Integra were squeeky as well
Old Apr 28, 2006 | 11:48 PM
MrEvoVIII's Avatar
That's not good to hear... Did it ever go away..?! b/c I wouldn't be able to put up
with it for too much longerr..
Old Apr 29, 2006 | 05:04 PM
evo_dadi's Avatar
put a little bit of silicone grease on the pillowball by the camber plates this usually helps.
Old May 23, 2006 | 08:45 PM
MrEvoVIII's Avatar
thanks for the suggestion!! this fixed it right up.. I actually put some heavy duty grease on the top and bottom of the pillowball mount plates... squeaked a few more times until the grease worked its way in I guess. Thanks again...
TxFAkuma
45
Feb 24, 2017 05:19 AM
cedes14bamg
Lancer Engine Tech
Nov 9, 2010 07:11 PM
CrackerJackToy
18
Dec 6, 2007 08:10 AM
Speed Ball
27
Dec 3, 2006 01:43 AM
pickleknock
12
Aug 16, 2003 10:17 AM
