-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   Won a set of Bridgestone's what size? (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/315405-won-set-bridgestones-what-size.html)
Onyxeros Dec 27, 2007 02:30 PM
Hey guys
I was involved in a silent auction and I won a gift certificate from Bridgestone for any size, any brand set of tires.
I am almost 100% certain I want the RE-01R's and I will buy another set of wheels for them and only in 17in.
What size would you guys recommend 245, 255?
or is there another bridgestone tire I should pay attention to?
Thnx
derangedazn Dec 27, 2007 05:41 PM
are you going to put them on your stock rims?
atombomb33 Dec 27, 2007 06:15 PM
What type of driving do you do? Do you do any HPDEs or AutoX? Drag race?
If you're going to buy new wheels for these new tires (which I think is what you said above) then I would suggest getting 17x9 and you'll definitely want 255s.
Good luck!
RoBear Dec 27, 2007 06:22 PM
You're on the right track with the RE-01R's. I just got them and I LOVE them! We need to know your wheel size and suspension set-up before we can recommend sizes.
Onyxeros Dec 27, 2007 08:00 PM
Wheel size can be what ever, like i said i will buy dedicated wheels for these tires. Eventually I will run an upgraded suspension but for now think of this as a completely stock evo with yet to be determined wheel width (ideally no spacers and no fender rolling). Since im getting a set of tires for basically the price of 1 i can spend a little more on wheels, maybe 9 - 9.5?
marcmags Dec 27, 2007 08:16 PM
whats the tread wear of the RE-01's
atombomb33 Dec 27, 2007 08:32 PM
Or, here is another idea if you don't NEED new tires for your Evo :cool:
Keep your current tires.
Get the RE-01s in 235/45/17 or 255/35/18 and sell them on EvoM. Those are two of the most popular tire sizes for Evo owners. You would sell them in heartbeat and could pocket the money :lol: :beer:
owenxguo Dec 27, 2007 08:47 PM
what you gonna do with them? between 245 and 255, I will pick 255.
housedj Dec 27, 2007 08:59 PM
depends on the size. some are 140A A, some are 180A A. here are the specs on all the sizes:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
for example, it looks like the 235/40ZR17 would work better than the 235/45ZR17 because it is 2lbs lighter. it also has the better treadwear making it a lil stickier. if i was getting a deal like the OP's i would get these or the RE050A's which are 24lbs in the same size 235/40/ZR17 but the tread width on those is .3" narrower than the RE-01R's...
Onyxeros Dec 28, 2007 05:14 AM
I am going to drive on them {thumbup}
honestly I am going to do 90% summer only street driving with 1 or 2 hotlapping on the open days we have out here
spdracerut Dec 28, 2007 07:47 AM
I'd probably go 255/40 on a 17x9 wheel. I don't think you'll need to roll the fenders sticking with that size.
DaWorstPlaya Dec 28, 2007 08:56 AM
+1 ... 255/40/17 tire and 17x9 rim 35 - 40 mm offset. Minimal splash gaurd rubbing under full lock and no fender rolling required.
theblue Dec 28, 2007 10:32 AM
yeah, 17x9 or 18x9 with 255 wide
Onyxeros Dec 28, 2007 01:09 PM
255's it is, thanks guys
housedj Dec 28, 2007 01:47 PM
if u get the RE-01R's in a 255/40ZR17 they weigh 28lbs. if u get them in a 255/35ZR18, they weigh 27lbs. ur choice
