Won a set of Bridgestone's what size?
Hey guys
I was involved in a silent auction and I won a gift certificate from Bridgestone for any size, any brand set of tires.
I am almost 100% certain I want the RE-01R's and I will buy another set of wheels for them and only in 17in.
What size would you guys recommend 245, 255?
or is there another bridgestone tire I should pay attention to?
Thnx
Thnx
What type of driving do you do? Do you do any HPDEs or AutoX? Drag race?
If you're going to buy new wheels for these new tires (which I think is what you said above) then I would suggest getting 17x9 and you'll definitely want 255s.
Good luck!
Good luck!
Wheel size can be what ever, like i said i will buy dedicated wheels for these tires. Eventually I will run an upgraded suspension but for now think of this as a completely stock evo with yet to be determined wheel width (ideally no spacers and no fender rolling). Since im getting a set of tires for basically the price of 1 i can spend a little more on wheels, maybe 9 - 9.5?
Or, here is another idea if you don't NEED new tires for your Evo
Keep your current tires.
Get the RE-01s in 235/45/17 or 255/35/18 and sell them on EvoM. Those are two of the most popular tire sizes for Evo owners. You would sell them in heartbeat and could pocket the money
depends on the size. some are 140A A, some are 180A A. here are the specs on all the sizes:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
for example, it looks like the 235/40ZR17 would work better than the 235/45ZR17 because it is 2lbs lighter. it also has the better treadwear making it a lil stickier. if i was getting a deal like the OP's i would get these or the RE050A's which are 24lbs in the same size 235/40/ZR17 but the tread width on those is .3" narrower than the RE-01R's...
