-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   Bedding Req'd If New Pads = Old Pads? (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/386214-bedding-reqd-if-new-pads-old-pads.html)
BoostLover99 Dec 8, 2008 12:30 AM
Do you have to bed new pads even if they're exactly the same brand and model as the old pads?
IOW, I run Ferodo DS 2500 all around (stock rotors); let's say that my rotors last through this set of pads and I get new pads, again Ferodo DS2500s.
Do I have to bed the new pads? Wouldn't the pad transfer onto the rotors be exactly the same as the material that's already on the rotors?
Kdash106 Dec 8, 2008 01:10 AM
yes u have to bed the new one again.
tephra Dec 8, 2008 02:57 AM
+1 yes u need to rebed.
Smike Dec 8, 2008 04:37 AM
Yep. Rebedding not only puts the material down on the rotor but it also burnishes the pad material. From the factory, most pads are heated in a furnace to chemically align the braking material. However, you still need to get the pads up to heat on your car to finish the process.
BoostLover99 Dec 8, 2008 01:55 PM
Cool - thanks!
MR White Dec 16, 2008 06:53 PM
Anyone have this issue when bedding pads. I bedded my pads per stoptech procedure. a week later I started getting loud squeal. Pulled the rear pads out and somehow lubricant I put on the rails and back of the pads ended up on the front. Not sure how this could happen. Thoughts?
tephra Dec 16, 2008 07:01 PM
too much lube?
not high temp lube?
