Bedding Req'd If New Pads = Old Pads?
Old Dec 8, 2008 | 12:30 AM
BoostLover99's Avatar
Do you have to bed new pads even if they're exactly the same brand and model as the old pads?
IOW, I run Ferodo DS 2500 all around (stock rotors); let's say that my rotors last through this set of pads and I get new pads, again Ferodo DS2500s.
Do I have to bed the new pads? Wouldn't the pad transfer onto the rotors be exactly the same as the material that's already on the rotors?
Old Dec 8, 2008 | 01:10 AM
Kdash106's Avatar
yes u have to bed the new one again.
Old Dec 8, 2008 | 02:57 AM
tephra's Avatar
+1 yes u need to rebed.
Old Dec 8, 2008 | 04:37 AM
Smike's Avatar
Yep. Rebedding not only puts the material down on the rotor but it also burnishes the pad material. From the factory, most pads are heated in a furnace to chemically align the braking material. However, you still need to get the pads up to heat on your car to finish the process.
Old Dec 8, 2008 | 01:55 PM
Cool - thanks!
Old Dec 16, 2008 | 06:53 PM
MR White's Avatar
Anyone have this issue when bedding pads. I bedded my pads per stoptech procedure. a week later I started getting loud squeal. Pulled the rear pads out and somehow lubricant I put on the rails and back of the pads ended up on the front. Not sure how this could happen. Thoughts?
Old Dec 16, 2008 | 07:01 PM
tephra's Avatar
too much lube?
not high temp lube?
