Will it rub? P45r's
I'm looking into a set of Rota P45R's, 18X9.5 +20. Not sure on the tire size...probably 245s, not positive. I was wondering if any one who has them or is good with wheels could tell me if I might have any fitment issues on stock suspension? or lowered on swift spec r's? Will I need to roll the fenders or need spacers at all?
I'm trying my best to learn about wheels and offsets, it's just hard to predict these things I suppose. |
Also, just found this in the p45r thread
Originally Posted by gomezgoku
(Post 4261155)
Here are mine. Just got them in today. So far no rubbing or anything like that. Im on stock suspension. It does stick out a bit more than i would like in the front but im not complaining.
18x9.5 P45R Royal Black et25 in front 3mm spacer, et30 rear. 245/40/18 Toyo T1R |
245 width is almost the stock size. Why would you run a stock size tire on a wheel that is 1.5inches wider? You can run 265s on those wheels.
Like I said I'm not sure on the tire size, they're used and the guy hasn't answered me on tire sizes...so...
Sir
Continue your research until you know exactly what youre getting into. IMO, any low wheel offset +30 and below will probably require some level of rear fender roll & even a pull depending on tire size. Look at this pic. If your wheel/tire pkg cannot float into the well then it doesn't fit. I read & heard guys say, "Well it only rubs when I have a passenger or hit large dips":crap: That kind of mind set is not right Joe BTW, That pic shows a +29 wheel w/ a 275 tire http://img574.imageshack.us/img574/6...8095resize.jpg |
Originally Posted by R. Burgundy
(Post 10244372)
Amirite? http://weknowmemes.com/wp-content/up...te-240x180.jpg Here: http://www.rimsntires.com/specs.jsp OEM is 17x8 +38 235/45R17 |
Originally Posted by Smike
(Post 10244664)
Not hard to predict. It's just maths.
Amirite? http://weknowmemes.com/wp-content/up...te-240x180.jpg Here: http://www.rimsntires.com/specs.jsp OEM is 17x8 +38 235/45R17 And that baby cracked me up :lol: |
They're 255/35/18...
From that program it seems like it would fit with possible rear rolling, and definitely spacers for the front brakes |
+20 is not a good offset. I would look at 35 (or if you have to +30).
you are going to need to roll your fenders and possibly even pull them a bit.
| All times are GMT -7. The time now is 11:40 PM. |
