Will it rub? P45r's
Old Jun 25, 2012 | 04:22 PM
R. Burgundy's Avatar
Will it rub? P45r's
I'm looking into a set of Rota P45R's, 18X9.5 +20. Not sure on the tire size...probably 245s, not positive. I was wondering if any one who has them or is good with wheels could tell me if I might have any fitment issues on stock suspension? or lowered on swift spec r's? Will I need to roll the fenders or need spacers at all?
I'm trying my best to learn about wheels and offsets, it's just hard to predict these things I suppose.
Old Jun 25, 2012 | 05:03 PM
Also, just found this in the p45r thread
Originally Posted by gomezgoku
Here are mine. Just got them in today. So far no rubbing or anything like that. Im on stock suspension. It does stick out a bit more than i would like in the front but im not complaining.
18x9.5 P45R Royal Black et25 in front 3mm spacer, et30 rear.
245/40/18 Toyo T1R
Now would +20 be worse or better than +25 in terms of fitment? Would I need a bigger spacer, etc?
Old Jun 25, 2012 | 05:16 PM
Craig King's Avatar
245 width is almost the stock size. Why would you run a stock size tire on a wheel that is 1.5inches wider? You can run 265s on those wheels.
Old Jun 25, 2012 | 05:36 PM
Like I said I'm not sure on the tire size, they're used and the guy hasn't answered me on tire sizes...so...
Old Jun 25, 2012 | 05:40 PM
Sir
Continue your research until you know exactly what youre getting into. IMO, any low wheel offset +30 and below will probably require some level of rear fender roll & even a pull depending on tire size.
Look at this pic. If your wheel/tire pkg cannot float into the well then it doesn't fit.
I read & heard guys say, "Well it only rubs when I have a passenger or hit large dips" That kind of mind set is not right
Joe BTW, That pic shows a +29 wheel w/ a 275 tire
Old Jun 25, 2012 | 06:57 PM
Smike's Avatar
Not hard to predict. It's just maths.
Amirite?
Here:
http://www.rimsntires.com/specs.jsp
OEM is 17x8 +38 235/45R17
Old Jun 25, 2012 | 07:47 PM
Amirite?
Here:
That is seriously cool. Thanks for this!
And that baby cracked me up
Old Jun 25, 2012 | 10:40 PM
They're 255/35/18...
From that program it seems like it would fit with possible rear rolling, and definitely spacers for the front brakes
Old Jun 26, 2012 | 10:38 AM
Smike's Avatar
+20 is not a good offset. I would look at 35 (or if you have to +30).
Old Jul 7, 2012 | 08:19 AM
CrazyLilPunk's Avatar
you are going to need to roll your fenders and possibly even pull them a bit.
R3P5AJ
May 5, 2011 06:42 PM
siikEvo92
Apr 28, 2011 06:50 AM
eddiel6l
Mar 31, 2011 05:03 PM
jtyler
May 24, 2010 09:01 PM
ries
171
Mar 3, 2008 06:31 PM
