Bump Steer on stock suspension.
Hello, I have been having some problems with some pretty bad bump steer for a while now. My car was also pulling to the side so I thought a alignment would fix it but when my friend did my alignment everything was green except the cross-camber, which I was skeptical about but he said he couldn't change that. Of course it still pulled to the right and the bump steer was still just as bad.
So I know that the cross-camber being off must be whats making the car pull to the right but what is causing this bump steer? I read on the internet that bump steer has to do with if the tie rod and control arm are different lengths, or sit at different angles, or a combination of the two. So is the tire rod thing the reason for the bump steer or the cross-camber or a bit of both? I have never heard of someone with bump steer on a evo unless they lower the car. Please help evom community, driving like this is unsafe :[ !! |
how do you know you have bump steer?
Originally Posted by griceiv
(Post 10868566)
What are the specs of your alignment?
http://img20.imageshack.us/img20/1130/onp6.jpg
I know the car is pulling to the right I think because the huge difference in the front tires camber. I know before he printed it the only thing in red was the "cross camber" which I know must be because the front camber variance. Though I don't think this would cause bump-steer since lots of people told me camber only causes a pull not bump-steer. |
Getting that camber fixed would be a good start I think...
Originally Posted by Raptord
(Post 10869390)
Has your car even been an accident involving the right front? On stock suspension the only adjustment for camber is with the eccentric bolt which has a -1 or -2 setting so it is strange to see a -.4.
Forget about bump steer at this point. Get your alignment straightened out 1st then report back. |
Originally Posted by heel2toe
(Post 10869440)
Forget about bump steer at this point. Get your alignment straightened out 1st then report back. http://img16.imageshack.us/img16/2965/hwud.jpg |
Looks like just a frame brace?
(Post 10869563)
Difference of 2 degrees between left and right is quite big, yes. Are the camber bolts pointing in the same direction?
Something clearly isnt right with the camber. OP is your suspension completely stock? If not please share with us what has been changed.
you don't have a bump steer problem, you have a crappy alignment. negative camber and large cross camber will definitely make the car wander over bumps (not the same as bump steer which is a suspension geometry design issue).
I see.... well the suspension is 100% stock as far as I know. So still not a clue why its off so bad, I will check if the bolts are facing the correct way like I was asked though.
Guess I need to take it to a REAL alignment shop instead of my friend doing it at his dealership |
