how to remove pad deposits from the rotor ?
have seen quite a bit of posts that say rotors do not warp, they just have uneven pad deposits that cause vibrations when breaking
my car acts the same and I'm not quite positive to turn the rotors and remove some life from them. so is there any DIY way to clean rotors ? will sandpaper do the job ? it began when I braked hard from ~110mph an experienced so called break fade. after that every time my brakes get slightly hot it vibrates when stopping from ~60 mph |
Two peice rotors dont warp. One peice may.
Explain your reasoning for that please.
any rotor or friction ring that gets really hot then cooled really fast can warp.
**edit: the remainder of "warped" rotors are uneven pad deposits. |
Originally Posted by cfdfireman1
(Post 11310575)
http://www.centricparts.com/files/Wh...ake%20Disc.pdf
http://www.stoptech.com/technical-su...eposit-removal how to resurface rotors for DIYers and shade tree mechanics. |
Ok
Originally Posted by kaj
(Post 11311669)
any rotor that gets really hot then cooled really fast can warp.
(Post 11311808)
so a 2 piece can't "get really hot then cooled really fast"?:confused:
Two different materials hat vs ring expanding at different rates allows for some "give" where as a one piece must expand uniformly or suffer from warp.
(Post 11311664)
Originally Posted by Grimgrak
(Post 11312031)
right ;-) |
Op ive been there.inspect your rotor surface from both sides first. Are they evenly flat or one side is more rough then other.the reason is if wear is uneven it might be your caliper pistons not clamping evenly.in my situation i had to purchase caliper seals from rock auto.thanks to our friend cfdfireman1 here :)
i have a deglazing wheel. it looks like a ball cylinder hone. anything that can sand the surface would work, as long as it's not so aggressive that it can make the surface uneven. brembo rotors are pretty hard so that helps.
is it acceptable to leave old pads after turning or cleaning the rotors ?
or the new pads are mandatory |
Originally Posted by stunt2
(Post 11313395)
