Which way to turn tie rod for toe adjustment
So with my driver and passenger wheels off. On the driver side, sitting looking into the wheel well, when turning the tie rod clock wise, will that toe in or toe out the driver wheel? Same thing for the passenger side sitting looking into the wheel well. Turning the tie rode clock wise, will that toe in or toe out the passenger?
So tl;dr of what I'm looking for... Below is correct, updated after figuring it out. Driver side Turning tie rod clockwise = toe in Turning tie rod counterclockwise = toe out Passenger side Turning tie rod clockwise = toe in Turning tie rod counterclockwise = toe out Thanks! |
The tie rod is behind the ball joint so the longer you make it, it'll push the backside of the wheel outward which moves the frontside inward aka itll toe it in. Shortening the tie rod will have the opposite affect.
I don't recall them being LH threads so in both cases tightening them aka turning clockwise will yield tow out. |
Originally Posted by heel2toe
(Post 11875463)
I don't recall them being LH threads so in both cases tightening them aka turning clockwise will yield tow out. Driver side Turning tie rod clockwise = toe out Turning tie rod counterclockwise = toe in Passenger side Turning tie rod clockwise = toe out Turning tie rod counterclockwise = toe in Correct? |
Yes, correct
Thanks!
(Post 11875463)
I don't recall them being LH threads so in both cases tightening them aka turning clockwise will yield tow out. So what was said earlier which was.... Driver side Turning tie rod clockwise = toe out Turning tie rod counterclockwise = toe in Passenger side Turning tie rod clockwise = toe out Turning tie rod counterclockwise = toe in I think the correct way was actually... Driver side Turning tie rod clockwise = toe in Turning tie rod counterclockwise = toe out Passenger side Turning tie rod clockwise = toe in Turning tie rod counterclockwise = toe out |
Service manual answer is here:
https://cimg5.ibsrv.net/gimg/www.evo...0a59697a51.jpg |
If all else fails... just look at the thread, and picture in your head what turning it in either direction will do to the overall tie rod length, and consequently the toe of the wheels.
longer tie rod = more toe-in shorter tie rod = more toe-out |
^This is the concept I was attempting to convey as opposed to memorizing if its clockwise or counterclockwise. The location of the tie rod front vs back is what dictates whether shortening or lengthening toes the wheel in or out.
Originally Posted by Raptord
(Post 11875473)
longer tie rod = more toe-in shorter tie rod = more toe-out Edit: I get it now. I was visualizing turning the actual End link. The manual is noting just turning the end link rod. Im good LOL |
I'm pleased to see someone playing with toe. Once you figure out how to measure toe, being able to adjust it is so handy for when you replace a part on the front suspension or hit a pothole to check for damage or when you find the steering wheel isn't straight. Spend money on something else.
