Everything to know about evo 8/9/10 OEM wheels
UPDATE: Spreadsheet of Information:
https://docs.google.com/spreadsheets...it?usp=sharing Hello EvolutionM. I want to make a video (Boosted Films) about all the OEM (USDM) evo 8/9/10 wheels. Hoping for some help from the community. Year - Wheel Options: 2003 - 1) evo 8 Enkei only 2004 - 1) evo 8 Enkei only 2005 - 1) evo8 Enkei 2) evo 8MR bbs's 2006 - 1) evo9 Enkei 2) evo9MR bbs's 3) evo 9SE bbs's 2008-2014 - 1) GSR Enkei & 2) MR bbs's 2015 - 1)GSR Enkei 2) MR bbs's 3) FE Enkei So there are basically 6 different wheel options from 2003-2015. 3 Enkei's: 1)evo8 2)evo9 3)evo10 (FE option would make 4) 3 BBS's: 1)evo 8/9 MR 2)evo 9 SE 3)evo X MR Questions: 1) Did i miss any wheels? 2) What would you like to know about these wheels if I was to compare them all? 3) Is it safe to say all evo x wheels would work on a evo 8/9? 4) If no to question 3, whats ones are all compatible? I hope to answer all these question myself soon. But I know this community has a lot of knowledge to share to help out. I currently own all the enkei wheels (minus the evo X FE), but I want to buy all 3 BBS options if anyone has 1 wheel of each to sell. Thanks! Wheel specs: Evo 8 Enkei: size: 17" x 8" offset: +38mm bolt pattern: 5x114.3 centerbore: 67mm weight: 20.50lbs stock tire size: 235/45/17 Evo 8/9 MR BBS: size: 17" x 8" offset: +38mm bolt pattern: 5x114.3 centerbore: 67mm weight: 17.74lbs stock tire size: 235/45/17 Evo 9 Enkei: size: 17" x 8" offset: +38mm bolt pattern: 5x114.3 centerbore: 67mm weight: 20.17lbs stock tire size: 235/45/17 Evo 9 SE BBS: size: 17" x 8" offset: +38mm bolt pattern: 5x114.3 centerbore: 67mm weight: __ stock tire size: 235/45/17 Evo X Enkei (GSR) size: 18" x 8.5" offset: +38mm bolt pattern: 5x114.3 centerbore: 67.1mm weight: 22lbs stock tire size: 245/40/18 Evo X BBS (MR) size: 18" x 8.5" offset: +38mm bolt pattern: 5x114.3 centerbore: 67.1mm weight: 18.5lbs stock tire size: 245/40/18 |
Hey Paul
Ill comment on: No.3 = I ran the EvOX GSR's on my 9 for 2 years or so. The wheel size is: : 18x8.5" ; +38 offset ;5x114.3 ; 67.1mm centerbore AFAIK, all the X wheels were built in that size And yes, they are a true x-over fit-up on the CT9A. Obviously Brembo friendly. I ran a Toyo 255/35. No rear fender work required unless you run a 265 series (would need some neg camber or a roll) Joe |
Originally Posted by DontStopMe
(Post 11876549)
3 BBS's:
1)evo 8/9 MR 2)evo 9 SE 3)evo X MR |
bbk?
There are the Gray BBS wheels from 2005 Evo 8 MR. It would be beneficial to throw in the wheel weight of each type of wheel. |
Originally Posted by llDemonll
(Post 11876608)
MR SE is not a "real" trim, it's technically just an MR with an appearance package. the SE wheels are the ones that are different (the light mercury silver color)
Were the evo 8/9 MR SE BBS (black diamond) wheels only available on the evo9's? I think so... while the 8/9 MR BBS's (gray) wheels could come on the 05 evo 8's and the evo 9. |
Originally Posted by deylag
(Post 11876611)
bbk?
There are the Gray BBS wheels from 2005 Evo 8 MR. It would be beneficial to throw in the wheel weight of each type of wheel. I hope to get the weight of all wheels for comparison. |
I've heard evo 8/9 17" wheels will not clear evo X brembos. Can anyone confirm?
(Post 11876626)
There are a few threads out there confirming the non fit of the CT9A wheels on the X Heres one post from our Robevo noting they do not fit due to the larger rotor (post no.3) https://www.evoxforums.com/forums/sh...d.php?t=306050 |
(Post 11876622)
And yes, I'd consider it a different wheel than the gray MR wheels |
Worth noting there is a slight difference between the MR BBS wheels and the SE BBS wheels aside from color. The inner barrel has a different design; this was discussed on here somewhere recently along with pictures. There is a chance the weights of these wheels are slightly different as well.
Originally Posted by heel2toe
(Post 11877038)
Not sure if it's worth making a video on this, but I did create a spreadsheet.
https://docs.google.com/spreadsheets...it?usp=sharing |
Are you going to tackle the JDM and UKDM wheel options?
Also what about Evo 7 wheels? |
Adding some visual to this
Hello, everyone.
I have bbs rims but the valves caps are no longer the original.. someone would know where I can buy some? Merry Christmas |
