ETS (Extreme Turbo Systems)- Evo X dyno tuning results thread
Old Dec 11, 2008 | 10:18 AM
  #31
jsdude's Avatar
washington best shop ever
Old Dec 11, 2008 | 11:32 AM
  #32
SunKren's Avatar
Agree.
Old Dec 11, 2008 | 02:04 PM
  #33
EVOXSILVER's Avatar
Update:
With a pretty simple setup with the HKS EVC 6 (Fun 5 mode RPM/throttle) i now boost up to 26,5 Psi and drop to 24 at 7000 RPM.
I guess the full exhaust system will greatly prevent from back pressure.
Old Dec 11, 2008 | 04:03 PM
  #34
JayDub514's Avatar
I see a 4" ETS FMIC in my future...
Great info guys!
Old Dec 12, 2008 | 11:38 AM
  #35
ETS Michael's Avatar
Originally Posted by SunKren
Agree.
Thanks Guys!
Originally Posted by EVOXSILVER
Update:
I can't wait to see the results with the full setup. Great job man!
Great info guys!
I have them on the shelf ready to ship! Let us know when your ready!
Thanks!
Michael
Old Dec 23, 2008 | 10:48 PM
  #36
gunzo's Avatar
Mike .. question for you guys ..
When you fitted your IC 3.5" .. did the car lean out ??
I checked mine .. and it didn't .. infact .. it ran richer .. ???????
Which brings me to another point .. another forum guy lost 20hp switching to a bigger IC (no names) .. doesn't sound logical but it happened (operator claimed its the poor FMIC design)
Care to explain how that is possible ?? (basically extol the good designs on the ETS FMIC please )
Old Dec 24, 2008 | 12:11 AM
  #37
jsyang15's Avatar
nice numbers!
Old Dec 29, 2008 | 10:06 AM
  #38
Our 3.5" intercoler does make the car run richer and it also increases airflow/boost. It also increases the power up to 17hp. (24hp for the 4")
Here is some discuission.
Because of the additional Airflow, the car will run richer based upon Airflow Map, which really richens the car up in the higher airflow areas. We observed that with the IC, the car made a max of 17hp over the stock unit, but there was a spot at 5700-6200 that the power dipped down to stock IC levels. This dip is when the car richens to 9.8 AFR. The reason that the car gets so rich is because of the increased airflow past the MAS. If it wasn't for a greater air density, the car would likely sputter out from being so rich. With the 4" cooler, this dip was less pronounced, and we feel the reason it is less pronounced is because of the greater air density ( more oxegen ). This brings us to how an inferior IC could cause a loss in power.
If an IC is really free flowing, but not efficient it will likely run very rich and possibly have spark issues. A good example would be an Ebay style core. These cores have internal fins that flow strait through. (You can actually see daylight through these units). If this kind of core was fitted to an Evo 10, there would be alot of airflow as observed by the Mass Airflow Sensor. When the computer sees this high airflow rate, it will inject more fuel and make the car run richer, just as we observed with our intercoolers. Now if the intercooler cannot cool the air well and increase the density, then the oxegen content of the charge air will be low. Because of the low oxegen content, and and the high airflow rate past the MAS, this make for a very rich situation in wich the car could make less power, have a sputtering issue, or most likly be on the verge of spark break-up and just have really choppy power. This is what our speculation would be if a high flowing, low efficincy cooler was fitted to an EVO 10.
Things that can contribute to a highflow / low efficiency unit are:
Low Density Fins
Small Size
Short Tubes
Low heat transfer area
Combinations of above
Hope this helps
ETS Sales Team
Old Jan 8, 2009 | 08:10 PM
  #39
LVSBB6's Avatar
Any dyno figures on the ETS downpipe? I have in the market for one and wanted to see your result before i decide. Thanks!
Old Jan 8, 2009 | 08:36 PM
  #40
Methodical4u's Avatar
Originally Posted by MS6_2nr
nice numbers... it seems like it is a lot easier to make good power with these cars then my old mazdaspeed6 was
That's because most Mazda's suck
Old Jan 9, 2009 | 08:54 AM
  #41
Very soon. We are finishing up a couple more products so we can dyno test everything together. We are going to have a couple very nice products out for the Evolution X shortly.
Old Jan 9, 2009 | 09:44 AM
  #42
EVOLVEU's Avatar
Damn thats awesome!!!
Old Jan 22, 2009 | 11:02 AM
  #43
samohopar's Avatar
It's been a while, any updates? I would really like to see all the mods + tune dyno, maybe even with 1/4 mile times
Old Jan 22, 2009 | 11:04 AM
  #44
LVSBB6's Avatar
I would like to see the gains on the downpipe...
Old Jan 22, 2009 | 11:34 AM
  #45
I will have some good updates to post up shortly. I think we are getting our back either today or tomorrow. The tracks are closed tell April here. We don't have a track open in the winter due to the weather conditions.
I'm hoping tomorrow! The car should either show up today or tomorrow.
