DG Motors Evo tuned: 331whp/320wtq
Old Apr 4, 2009 | 07:15 AM
  #31
REDEVO08's Avatar
PM sent
Old Apr 4, 2009 | 11:02 AM
  #32
DG Motors's Avatar
Originally Posted by blackdemon
My Air/Fuel ratio is about the same pete. No knock
Hey, I have an evo X coming down sunday after 2 p.m for a tune and a few getting some baseline pulls. We may be firing up the grill if you wanna b.s and have a burger. We took off this Saturday(today) so we can all get some rest..It has been a busy week!
Old Apr 4, 2009 | 11:03 AM
  #33
DG Motors's Avatar
Originally Posted by REDEVO08
PM sent
Pm replied!
Old Apr 4, 2009 | 06:14 PM
  #34
blackdemon's Avatar
I'll let you know. Might be busy tomorrow Might be going back there next week with charlie anyways as the vr4 is getting tuned and the blue sti is also getting tuned after the boost controller gets put in.
Old Apr 4, 2009 | 11:30 PM
  #35
nj1266's Avatar
We are spiking 25psi and holding it until 6500rpm then it does taper to 22psi at 7800rpm!
Is this with all three stock boost pills in place?
Old Apr 5, 2009 | 09:59 AM
  #36
DG Motors's Avatar
No, we have no use for them
  #37
DG Motors's Avatar
Sounds good.
Old Apr 6, 2009 | 03:09 PM
  #38
DG Motors's Avatar
Originally Posted by packed
Nice #'s. I want a EVO X!
Theses machines are starting to impress me!
Old Apr 6, 2009 | 03:56 PM
  #39
wtevo8's Avatar
The X's are starting to come to life!
Old Apr 6, 2009 | 04:10 PM
  #40
REDEVO08's Avatar
Few more hours til mine comes to life
Old Apr 6, 2009 | 04:34 PM
  #41
Peterr928's Avatar
nice numbers
Old Apr 6, 2009 | 04:51 PM
  #42
DG Motors's Avatar
Yep, just hold out a little while longer! see you @ 2!
Old Apr 6, 2009 | 04:57 PM
  #43
nj1266's Avatar
There are two ways to control boost through the ECU that I know of:
1. You keep the stock pills on the solenoid side in place and you use a smaller restrictor pill on the turbo side.
2. Remove all the pills and swap in a 3-port solenoid. Did you change the dual solenoids to a GM 3-port or equivelant?
With both hardware changes require adjusting the WGDC table and the BDEL tables.
Is there a third method that you are using? Are you flashing the car with ECUflash or using a COBB AP?
Old Apr 6, 2009 | 05:31 PM
  #44
DG Motors's Avatar
Ecuflash. I've had 0 problems tuning evo X's via ecu controlled boost with all the pills in place or none of them at all.
Old Apr 6, 2009 | 10:14 PM
  #45
DG Motors's Avatar
As long as people enjoy how I do business and treat my customer's/friend's, I will be able to expand my knowledge and further rip into these ecu's!!!
Originally Posted by Peterr928
nice numbers
Thank You. The average evo 8 full bolt-on's with cams barely broke 320whp on pump gas. The average evo 9 with full-bolt on's w/ no cams barely broke 330whp on pump gas. A solid evo 9 with full bolt on's w/ cams and an aggressive pump gas tune will usually do 335whp-355whp around 24-25psi. All stock turbo ofcourse
