Cobb stage 2 - 313 whp
Old Apr 6, 2009 | 06:37 AM
Boba's Avatar
T1R turboback, T1R intercooler pping, AEM CAI, AP Cobb stage 2 93 octane - 313 whp and 520 Nm
baseline was 249,9 whp.
Old Apr 6, 2009 | 06:48 AM
Clark_Kent's Avatar
So you picked up 163whp with listed mods?
Old Apr 6, 2009 | 06:52 AM
Boba's Avatar
oops, sorry, baseline was of course 249,9 whp
Old Apr 6, 2009 | 06:53 AM
Boba's Avatar
edited ))
Old Apr 6, 2009 | 11:08 AM
BigT's Avatar
So the stage 2 map worked with your AEM intake? Or, did you get custom tuned? Nice numbers by the way.
Old Apr 7, 2009 | 01:07 AM
Boba's Avatar
No custom tune, just installed Stage2 with COBB SF Intake, using 93 Octane fuel. I know it may be dangerous, but it is works very good!
Old Apr 7, 2009 | 01:09 AM
Boba's Avatar
AFR was from 13 to 11 under full load.
Old Apr 13, 2009 | 01:24 PM
SPEEDPIMP's Avatar
what was your boost set at? any knock count during the runs?
Old Apr 16, 2009 | 10:10 AM
Boba's Avatar
my peak boost was 1.8 (3000-5500 rpm) bar tapering down to 1.5 bar by the red line
according to AP logs knock retard was maximum 4.22
Old May 14, 2009 | 05:42 PM
Farred's Avatar
is it just me or does 313 seems kinda high for those mods. was it a dyno that reads high or do you have a factory freak?
Old May 14, 2009 | 06:01 PM
ScottSpeed21's Avatar
He has an intake, intercooler pipes and a full turboback exhaust. People have made around 350whp or more with those mods on a custom tune. I'd say 313 isn't too bad for an off the shelf map on the AccessPort. Probably a pretty conservative tune.
Old May 14, 2009 | 06:19 PM
stikllr13's Avatar
^^ Yea I have 325whp with just a cat-back and intake but with a custom tune. So 313 with an off the shelf map is just about right.
Old May 15, 2009 | 04:52 AM
Farred's Avatar
sweet. well i should have all that put back on in a week or so. woot!!
Old May 15, 2009 | 06:10 AM
newcomer81's Avatar
it fully depends on the dyno used
my mediocre mods pulled me 350wtq/300whp @20 psi falling to 14 with a tune on a dyno dynamics. so if you use the numbers found here: http://zilvia.net/f/tech-talk/230182...-some-fyi.html
24) How do I compare my pulls to Mustang Dyno, or a Dynojet, or a Dynapack? Every dyno is different. If you want dynojet or mustang-ish #s you have to multiply by 1.18 or so, 1.25+ for DynaPack. But remember, this is just ballpark, as it is not linear.
take this numbers and i would be at 413/354 or 437/375. now i am not sure i believe that but it illustrates the point that any given number is only valid to the baseline that was run before a tune or parts are added.
Old May 15, 2009 | 09:37 AM
Yikes! That drops a lot, get yourself a boost controller or tighten up your wastegate actuator or something. I'm at 20psi by redline.
