HB Speed Retunes another X!!
Old Jul 2, 2009 | 12:50 AM
HB Speed's Avatar
car has
Ultimate racing Turbo back with o2 housing
AEM Intake
Cosworth cams
Upper IC pipes
and a Dejon MBC
i made a baseline pull on that tune ( and logged it)
I proceed to flash my base map to the car
and then i tune it a bit............... didnt need much from the baseline
here is before and after!!!
if you want to see afr and boost just click here and see for yourself !!
and many more evo X too!!
  • 07-01-2009 11:32 pm 319 hp 336 ft/lb Baseline
  • 07-01-2009 11:34 pm 350 hp 329 ft/lb HB Speed BASEMAP
  • 07-01-2009 11:55 pm 351 hp 345 ft/lb HB Speed Final Tune
Old Jul 2, 2009 | 09:50 AM
HybridKOOP's Avatar
HB Speed ROCKS. I'd go there and only there if I lived in the West!
Nice work!
Old Jul 2, 2009 | 10:05 AM
supergengo's Avatar
Did you eliminate the Dejon MBC and go with ECU boost control?
This car still seems down on power... you guys produce many cars with those power levels (like my car ) which don't have cams. Any thoughts?
Old Jul 2, 2009 | 12:35 PM
HB Speed's Avatar
BOOST
that is why
the car runs less boost than the others
compare it in the dyno database
Old Jul 2, 2009 | 12:36 PM
HB Speed's Avatar
w00t!
Old Jul 2, 2009 | 06:30 PM
1024's Avatar
good numbers
Old Jul 14, 2009 | 03:36 PM
tokeone's Avatar
did you guys do the cam install on that?
Old Jul 14, 2009 | 04:02 PM
HB Speed's Avatar
nope, we have done several cam installs, including the cams in our Evo X race car!
Old Jul 22, 2009 | 11:09 AM
SlickCT9A's Avatar
HB speed is awesome! really good guys and good at what they do
Old Jul 22, 2009 | 04:48 PM
SpeedI2acerX's Avatar
how much would a cam install cost and how long does it take?
Old Jul 22, 2009 | 04:53 PM
HB Speed's Avatar
PM'd
Old Jul 22, 2009 | 10:54 PM
evo_what's Avatar
nice! throw a Dominator 2 and some meth on and crack 400whp!
Old Jul 22, 2009 | 11:02 PM
Juju702's Avatar
very nice
Old Jul 24, 2009 | 01:35 PM
triguy's Avatar
Any downsides to the cams Jon after a tune in terms of drivability, emissions testing in CA?
Old Jul 24, 2009 | 02:58 PM
HB Speed's Avatar
not really any downsides with the stage 1's as far as driving/etc.
I have heard people passing smog no problem with mild cams
