Dyno4mance Tune Only TBE and UICP
Old Aug 20, 2009 | 07:53 PM
nbpal4000's Avatar
I had my car tuned at Dyno4mance last sat.
mod lists are:
UR Down Pipe + UR Test Pipe + UR Cat Back
UR UICP
The service was superb and the gain was substantial! I love the way my evo drives now!
Thanks to Andrew and Bruce at Dyno4mance
Old Aug 20, 2009 | 09:40 PM
murlo26's Avatar
Looks good, about where I would expect on 22-23ish psi. Bet it feels a lot better
Any reason you didn't boost up a little more, like 25 or so?
Old Aug 21, 2009 | 12:16 PM
J5isalive2's Avatar
Nice work! Gotta love Bruce and Andrew! They both take pride in their work.....real nice guys.
I got tuned there as well.... only a couple more mods and I put down 304whp. That dynodynamics sure is a heart breaker
John
Old Aug 21, 2009 | 11:01 PM
Titanium951's Avatar
Looks good!
Old Aug 22, 2009 | 05:31 AM
DVDee's Avatar
I don't know where you are or if this is a heartbreak dyno but the numbers seem kinda low to me.
Old Aug 22, 2009 | 07:58 AM
Noize's Avatar
EvoM Administrator
'Tis a heartbreaker dyno, plus it was 98 degrees in the shop. A completely stock X makes about 215whp.
I originally made 309 here, but in this heat, it was down to 294. HOT.
Old Aug 22, 2009 | 09:58 AM
skatermsmn's Avatar
THis dyno also has the capabililties of showing dyno jet numbers by setting it in shootout mode.
Old Aug 22, 2009 | 10:28 AM
murlo26's Avatar
Yup for instance here, my tuner has compared this to other dynojets, usually within a few percent.
Shootout mode is basically for fun, to try and compare to others that use the lame high reading dynos
Old Aug 22, 2009 | 10:54 AM
Noize's Avatar
EvoM Administrator
Shootout is higher than a dynojet.
Old Aug 22, 2009 | 11:01 AM
murlo26's Avatar
It depends on what correction you are using, it is usually higher by a few percent. You can put a dynojet into a reasonable correction factor but many places don't to make people feel all warm and fuzzy.
Old Aug 22, 2009 | 11:41 AM
mlomker's Avatar
Originally Posted by DSM_David
i want to start seeing some track times that go along with these 400 hp +
That usually has more to do with the driver than the car. Posers have some perfectly fine cars.
edwin
For Sale - Part Outs
125
May 10, 2011 04:32 AM
disturbedfan121
Dec 10, 2010 12:28 PM
chazyronnie
Nov 19, 2010 05:23 PM
alex3dworld
Evo X How Tos / Installations
22
Dec 27, 2009 08:50 PM
crazyspiritz
Sep 28, 2009 08:28 PM
