MAP EF3 Tuned by Rick @ Rallinspired
So on a different dyno, this car could make 60whp+ more....what do you consider the "REAL" results?
Also, if you had a strong understanding of math, you would know that the formulas VD uses for computing torque based off of speed over time, with weight and tire diameter etc actually produce very accurate numbers. (*again, when used correctly) They're all simple equations. My last tune was on CBRD's dyno and my VD #'s were within +/-5. Cobb has a similar feature on their Accessports too I believe.
I was asking the OP to post a virtual dyno chart up, not you. If you don't like it, it doesn't matter... a lot of people like to see it as a common ground for comparison.
VDR is a way that everyone, no matter your location, can share a common way to compare power as long as you put in the correct tire size, right gear and keep the weight of the car to a reasonable number.
I agree, it could be a useful tool IF people actually used it properly.
I can't ever get VD to be consistent. Same car, same road; I get 100-120 whp variances (you'd think a guy would notice if the car was actually making +/- 100whp :sarcasm: )
OP: Great looking power there, I love how fast it spools from 3-4k, must pull like a train
However, the black setup it's compared to isn't ideal. A better comparison is the black vs EF4. It's all in the setup, hard to compare two different cars and turbos.
