451whp FP Black Stock Block 2011 GSR
Old Dec 7, 2011 | 03:55 PM
badreligi0n's Avatar
Edit, Nice numbers!
Old Dec 7, 2011 | 05:15 PM
JohnBradley's Avatar
Originally Posted by evoforstevo
Ah ok that makes Sense. Didn't know that exhaust was restrictive
Better than stock of course, but in my opinion there are less restrictive options that will definitely make more power at the same boost level.
I offer as evidence the ETS V2 that was on Igor's EvoX made 440whp at 28psi on the FPBlack in an MR. It had all the same mods as Will's car with the exception of Kelford B cams because the S2X was not available.
The exhaust was a little too loud for Igor driving down the road so we switched JUST the muffler setup to the ETS Quiet setup (which is WAY larger than this muffler) and dropped 20whp. All of that was done on an MR which loses more power than the GSR. I have seen stock MR trans eat 9.5-10% power more than the GSR so that would have put Igor something like 480s? Add an O2 dump and that can climb another 20whp on the stock turbo let alone on a Black which really might pick up.
Aaron
Old Dec 18, 2011 | 05:19 PM
troyracin54's Avatar
niiiiiiiice
Old Dec 18, 2011 | 11:47 PM
ademarco's Avatar
Is the ETS quiet version that much more restrictive? This is the perfect power level for the X. I am going to try and replicate this in the future once the warranty runs out.
Old Dec 19, 2011 | 04:32 PM
Dynotech Tuning's Avatar
Nicely done Aaron
-Jamie
Old Jan 12, 2012 | 12:13 AM
jfeo's Avatar
wow sick numbers must be a blast to drive!
Old Jan 12, 2012 | 09:33 AM
Alpha X's Avatar
Awesome numbers!
Old Jan 12, 2012 | 11:21 AM
EvoStig's Avatar
Nice #'s!
Old Jan 12, 2012 | 11:44 AM
Thanks guys
Old Jan 12, 2012 | 09:55 PM
hpmx18's Avatar
looks great awesome
Old Jan 18, 2012 | 07:17 PM
Nickzorz91's Avatar
Is this build safe on the stock block because the wtq is capped at 360? What kind of HP will it take before needing new pistons/rods?
Old Jan 18, 2012 | 07:24 PM
We have made over 400 ft lbs on stock bottom ends without issues so far.
....well other than clutches
Old Jan 18, 2012 | 08:03 PM
murlo26's Avatar
I don't think 400 is the problem, i made over 400 for like 15k miles. It was the 460 ft/lbs that windowed my block.
I think 400ish is just a "safe" area, but still not for sure.
Old Jan 19, 2012 | 12:55 AM
EVO X 6950's Avatar
To the op, great number, and that tq curve looks smoooooth.
@murlo how long did you run the 460 wtq before the block went? Mine isn't sleeved and was just wondering if 420 wtq would be "safe"
Old Jan 19, 2012 | 08:35 AM
murlo26's Avatar
It was my rods that went not the sleeves, it was the stock block. Not long at all we'll say.
