Brent's 490whp/352 tq 35R with SD
Old Jan 12, 2013 | 01:47 PM
JohnBradley's Avatar
Standard off the shelf 3582 from Garrett with no special tricks. 4B11s run hot, a larger turbo has less backpressure which is less EGT. This results in longer engine life and more power.
I wouldnt call 9:1 low compression though either.
Old Jan 13, 2013 | 06:17 PM
scheides's Avatar
EvoM Moderator
Hah, on the stock catback even! Looks great. I guess I would have just stuck with a 3.5" MAF but I'm all for progress and trying out SD long-term. Looks good sir!
Old Jan 14, 2013 | 04:56 AM
whiteEvo08Y's Avatar
Lots of good power. Nice Video.Good job guys
Old Jan 15, 2013 | 08:37 PM
Original's Avatar
I just fell in love your car sounds soo good
Old Jan 19, 2013 | 02:30 PM
All of that is the testpipe dump, the stock cat back sounds well stock. A X and nearly open exhaust definitely has a unique note to it.
Old Jan 19, 2013 | 02:49 PM
DisgustipatedM3's Avatar
Originally Posted by Gyroscope
way too laggy, look at the lack of torque under 4000 rpms, i would hate to drive this on the street and have to constantly downshift to move. this isnt a high compression honda motor, it needs the boost down low!
Yeah, unfortunately I have to agree. The peaky power band resembles a boosted Honda motor. Someone else said 'it's so you can have 500 whp on the street on pump gas...' I think Evos are excellent at providing huge, usable powerbands even on pump gas. It reminds me of a high hp Honda S2000 powerband.
Old Jan 19, 2013 | 02:56 PM
When it comes back I'll do a pull in 4th gear to show it really feels on the street.
Old Jan 19, 2013 | 03:59 PM
candymanjl's Avatar
Ha ha, some people mentioned it already. Looks like my roommate's turbo S2000 powerband, just a little lower He's running a huge Borg Warner T4 turbo though, good for like 750whp or something like that.
Good numbers! I'm sure on the street it will load up more and spool up lower.
Help an EVO newb out please, SD? I'm guessing speed density?
Is there a way to run the EVO ECU based on the MAP sensor only and not worry about the silly MAF running out? Is that what you're talking about?
I hate MAFs personally, just seems more straightforward to run MAP only and not have to worry as much about leaks and BOV's venting to atmosphere.
Old Jan 19, 2013 | 05:04 PM
Correct this is speed density, using the factory 3.2 bar map sensor and completely bypassing the stock MAF sensor for fuel calculations.
Old Jan 29, 2013 | 11:47 AM
candymanjl's Avatar
Nice! Anything special in the ECU to set that up? I'll be using ECUflash on my car, got the Openport 2 coming, should be here tomorrow. Do you need to patch something or just tweak settings to ignore the MAF?
Old Jan 29, 2013 | 12:17 PM
Original's Avatar
I have a question:
How come the torque on this setup is so low, compared to whp? My buddy's EVO makes 400/360ish and the torque is close to those numbers.
Old Jan 29, 2013 | 12:34 PM
2 reasons-
Ignition Timing
Because of where it makes peak torque. Torque x rpm/5252 = hp, so after 5252rpm the torque will drop and the horsepower goes up. Since this makes peak power at 8,000 when we look at the math (and dyno sheet for that matter) we see it makes 321 ft lbs.
Your friends car is probably on a Green or something like that? It would spool 1000rpm sooner or more, make peak torque in the 4,000 range and peak power maybe mid 6,000r?
Let's say 6500 for peak power. This means at 6500 it makes 323 ft lbs there (for instance) where this car is making 349ish ft lbs and is still climbing in power toward redline.
aaron
Old Jan 29, 2013 | 12:41 PM
murlo26's Avatar
torque in any boosted car is related to spool and boost level. If you spool to 25psi on two setups but one is later in the rpm band (1000rpms later for instance) you could have the same torque level or lower on the slower spooling one. The trade off is sustained torque which lasts out to redline and doesn't drop off like the stock turbo for instance. If you can hold torque, HP increases with RPM.
The way to get more torque is to run higher boost or add displacement to add in spool to gain "peak torque" back.
You really shouldn't look at peak, its all about torque across the powerband and the "meat" of it.
Bigger turbos do flow more air at lower RPM's (more air, more potential power/torque)so its not always how I have portrayed it but in generality it is.
Edit: took a phone call at work while typing this, Aaron beat me to it, lol. His answer is essentially the same thing, maybe a bit more technical
Old Jan 29, 2013 | 01:20 PM
Darksun280's Avatar
My buddies car makes 200-500 tq. I don't know any specifics about his car. Why doesn't your car make as much as his car? Please explain.
Old Jan 29, 2013 | 01:56 PM
LOL
Darksun wins.
